Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 09-08-2014, 06:53 PM   #1
MCB Matt
MCB Matt's Avatar
NEW - Push Button Start with RFID key - Keep Your keys in your pocket.. MUST READ!
Hey guys, we are now Carrying Keyless entry/push button start systems. Just walk up to your car, it unlocks and you can jump in and hit the start button! They are a very high quality kit, worth of being installed in basic to super High end builds! These kits are under $499.... That is a VERY good price for all you ger
Please PM, email or call for details, there are several options available:
Below is a quick list of some of the features and options...
Start Button with LED Status Indicator
All 2GO Keyless™ come standard with our "T1 style" stainless steel LED Illuminated Start Switch. This is a top quality / heavy duty cycle switch with an attractive "soft brushed" finish. An Illuminated LED ring indicates system status. Switches are pre-wired to a 36" plug in harness. Available in 3 LED colors; RED, BLUE or GREEN.
Five Independent Feature Control Channels
Four channels are user programmable (either Latched or Pulse) can be used for virtually any option such as Remote Keyless Entry, Shaved Door “Pop” (single/dual), Remote Trunk release, Automatic Window Roll up, Lighting or Video activation, and a 5th "Proximity Channel" that activates automatically when you approach your vehicle, provides endless versatility to create customize operation of whatever you can dream up.
Advanced System Control Module
The system control module has 60A high current relays which are right on board, eliminating all unsightly and failure prone external relay wiring. Individually controlled circuits for Starter, Ignition and two separate Accessory circuits allows the system to install into any vehicle. One ACC circuit switches OFF during starter crank (to minimize current draw from components like A/C) and another that stays ON (for components such as computers.
Programmable Starter Delay
For vehicles requiring time for fuel to pressurize on other systems to warm up before the engine cranks. The PBS II provides a programmable Start Delay circuit. It allows you to select a delay from the time you press the start button until your starter cranks of up to 7 Seconds.
Built in MSD Filtering system
Advanced filtering circuitry removes noise and electronic spikes associated with many high performance ignitions, saving money an time by eliminating the need to buy separate ignition filters.
Full Ignition Switch Functionality
Using brake pedal controlled switching the system fully emulates the functions of a traditional key switch.
Want to operate accessories without starting your engine?
Just use the Brake to select between different Ignition modes:
"Accessory Only Mode" ( Radio )
"Accessory + Ignition Mode" ( Heating / Fans / Radio )
*** At any time you can go directly to "Start Mode"
Choice of Start Buttons
Customize your Ultimate Keyless installation even more with one of our optional Start Buttons choices. We start with of the most beautiful OEM buttons available and individually modify them to work with 2GOKeyless™. It's the perfect finishing touch!
Emergency Bypass
Should you ever lose or damaged your iTag™ the system includes a Emergency Backup PIN# Card that will allow you to start your vehicle in a emergency.
A 2GO KEYLESS™ exclusive feature!
MCB - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
Email: forums@mcbparts.com
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
MCB Matt is offline
Old 09-11-2014, 01:44 PM   #2
MCB Matt
MCB Matt's Avatar
Re: NEW - Push Button Start with RFID key - Keep Your keys in your pocket.. MUST READ
I have received quite a few emails about the RFID systems....
These are a LOT more affordable than they look! We have kits with RFID key, which means you keep the key in your pocket, walk up to your truck, it senses you and unlocks! Hop in and push the button and hold to start the truck or push briefly to turn on acc mode (radio, ect).
It comes with a wallet card so if you loose your keys, as long as you have your wallet, you are ok.
Once you walk away from the truck it will lock automatically too.
There is a remote start option and the hand held key fob has a 5 channel output so you can control anything that can be run by a relay! Think --- Power Windows, lights, air ride, power rear window, the options are almost endless...
These kits start under $399!!
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 10-22-2014, 04:07 PM   #3
MCB Matt
MCB Matt's Avatar
Happy Hump Day!!
Thank you for the business from the forum... Increasing everyday!!
We truly appreciate it!
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 11-12-2014, 05:00 PM   #4
MCB Matt
MCB Matt's Avatar
Happy hump day from Sunny Ca!
As always, many sales and hundreds of brands available!
Buy with confidence... Top notch service, great prices and we are always here to answer the phone Mon-Fri 9-5 pacific... No Cell phones, leaving messages, ect!!!
We enjoy talking to our customers and helping with product selection and we can put together a package for anything from basic restoration parts to all out Suspension and brake packages!
Thank you all very much for the rapidly increasing business from members here.
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 11-17-2014, 02:30 PM   #5
MCB Matt
MCB Matt's Avatar
Happy Monday from MCB!
We are happy to report that we are getting to know a lot of you on the forum and are now supplying parts exclusively for several builds and direct to quite a few shops as well! Business has been steadily increasing here by almost 50% a week so a HUGE thanks to you guys out there
We have a lot to offer this community that is very unique around here. We are Pro-Touring specialists, anyone can sell stock restoration parts, which we do as well, everything A-Z!!
Our main focus is in the "FUN PARTS"... The stuff the truck's weren't available with stock... The Vintage Air Kits, Dakota Digital VHX dashes, LSx swap parts, Disc Brake kits, Suspension packages/parts, Smoked Glass kits, Wiring kits, Power Windows, High quality radios to fit the stock dash with stock style knobs but with Bluetooth wireless audio streaming and phone calls as well as Kick panels with affordable, high quality speakers, 3 point seat belt kits... The list goes on!!
Anything you need for your truck, Blazer, Suburban... Chances are MCB carries it at a great price and top notch customer service!
Thanks again, you guys rock
Matt + Kim
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 12-04-2014, 08:03 PM   #6
MCB Matt
MCB Matt's Avatar
We wanted to thank all of our regular and new customers who took advantage of our Black Friday/Cyber Monday sales!
This was by far a record breaking sale / Year for us at MCB and we truly appreciate your business!
If you contacted us during the sale and were not able to complete your order before the sale end date, we will still accept your orders for the rest of the week! We were very busy and could only get so many orders entered, PM's replied and invoices sent.
We have many more exciting new products coming soon as well as sales! As always, your forum discounts apply throughout the year so let us know what you are after, we carry more Pro-Touring and stock restoration brands than just about anyone out there!
Remember, price increases typically always go into effect at the first of the year. We have no control over this and all we can do in encourage you to get your orders in if you can before then to save some cash! We will post Price increase dates as we receive them.
Happy holidays and thanks again from all of us at MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 12-12-2014, 05:40 AM   #7
Orangetonicclicc
Orangetonicclicc's Avatar
Hey Matt! I'm really interested in purchasing a Push Buttony proximity system for my 67. I have questions and need pricing with details. Please contact me'
Orangetonicclicc is offline
Old 12-12-2014, 01:37 PM   #8
MCB Matt
MCB Matt's Avatar
Ok, no problem, PM sent.
Matt
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 12-19-2014, 03:52 PM   #9
MCB Matt
MCB Matt's Avatar
Happy Friday! MCB is offering Holiday sales on everything we carry, call or PM and let us know what you need and what kind of prices you are seeing, we will do our best to take care of you!
We have had some GREAT feedback on the fit of the start button for the 67-72 trucks, the lexus slim button is a near perfect fit for the factory hole, just slight sanding and it's in... We have quite a few customers running these kits now with great success!
Thanks for the business, we are looking forward to a great 2015 here!
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 12-24-2014, 06:21 PM   #10
MCB Matt
MCB Matt's Avatar
Holiday prices good through the end of the year!
Happy Holidays and thank you for the business you have sent our way this year, we appreciate your trust in MCB even though we are new here on the truck forum, we have been in the biz 14 years now!
We have a lot of new products and specials coming up for 2015 so stay tuned!
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 01-23-2015, 02:02 PM   #11
MCB Matt
MCB Matt's Avatar
Happy Friday guys! Thank you for the business, we appreciate the orders!
PM or call for your forum prices!
Have a great weekend
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 02-02-2015, 03:54 PM   #12
MCB Matt
MCB Matt's Avatar
As always we have great pricing and service on these kits, just let us know which kit you are after and we will help you out.
You can call to discuss your project with us at 925-828-5555 or PM/Email.
We are working on quite a few exciting new things for 2015 here!
Thank you for your business as always, we appreciate it.
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 03-05-2015, 04:29 PM   #13
MCB Matt
MCB Matt's Avatar
Thank you all very much for your continued support!
We have some great sales going on right now and we will beat any legit quotes on the same part# as always!
Let us know what you need and we will get you a quote.
We are happy to put together a package for you if you aren't sure what you need.
Feel free to call us at 925-828-5555 or send a PM
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Old 03-11-2015, 01:09 PM   #14
MCB Matt
MCB Matt's Avatar
Happy Hump Day!
Thank you for the continued support, we appreciate your business.
We are always here to help, Mon-Fri 9-5 Pacific
Give us a call at 925-828-5555, PM or Email forums@mcbparts.com and let us know what you are after, we have just about every brand available for your truck from wheels, brakes, suspension, sheetmetal, Gauges, Wiring, Columns, Power Windows, Interior kits, Trim, LS conversion parts, Billet hinges and other pieces, basically... BUMPER TO BUMPER!
MCB
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
MCB Matt is offline
Closed Thread
