Old 08-10-2003, 11:56 PM   #1
ronniej
Unhappy Where can i find the right parts to lower my truck?
I have a 71' GMC C-2500 3/4 ton. i want to lower it and i can find the rear shackles and such to lower the back but i can not find dropped spindles for the front. is this because it has large disk brakes on the front or cause it is a 8 bolt wheel set-up. i have done a lot of looking but just have not found the right place. does anyone know where i can get parts to do this without changing out the whole front end? i don't want to drop it more than 2 to 3 inchs.
Thanks for any help.
ronniej
ronniej is offline   Reply With Quote
Old 08-11-2003, 01:59 AM   #2
Dallas2254
When you find out let me know too. Thanks, Dallas
dallas.evans@comcast.net
Dallas in Seattle
'72 KE20 LWB 4x4
'72 CE20 LWB
'71 KE10 SWB 4x4
427 shelby cobra
Dallas2254 is offline   Reply With Quote
Old 08-11-2003, 06:22 AM   #3
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
this will help lowering stuff for days
[FONT="Impact"][COLOR="Navy"]Michael
Lowered 1972 C-20 Longbed with 350 and TH350
1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights...
2009 Nissan Versa
I am 26, married, and we had our first baby in July of 2009
Iceman7642 is offline   Reply With Quote
Old 08-11-2003, 09:27 AM   #4
Randy70C-10
Randy70C-10's Avatar
If you're only dropping 2 or 3 inches, you may want to just use the dropped springs.
Randy70C-10 is offline   Reply With Quote
Old 08-11-2003, 10:00 AM   #5
wnc mountain
More hobbies than money!
wnc mountain's Avatar
take a look at ECE. click here!
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 08-11-2003, 12:39 PM   #6
kickboxr3
dropped
I was telling a friend about my buying the 2' drop springs for the front and he said , the way to go is drop spindle cuz it would not
affect geometry and just putting the 2' springs would not be the way to go. Any suggestions out there?
kickboxr3 is offline   Reply With Quote
Old 08-11-2003, 12:59 PM   #7
djracer
djracer's Avatar
Spindles are usually a better way to go but they sometimes require larger wheels they did on my 95 suburban. The stock wheels hit the control arms. Lowered coils are fine. Coils can even be cut if you don't over heat them. If you heat them too much they loose their temper and sag.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-14-2003, 02:05 AM   #8
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
the only thing i did to lower my front end on my c-20 was put in c-10 3" drop springs in. nothing else. i have no handleing problems on anything like that. So, it worked out for me.
Good Luck
2009 Nissan Versa
