09-09-2014, 02:57 AM | #1 |
Speedo Grommet
How do I get my new speedo grommet on my new cable?
How about the Emergency cable grommet? So far i just cut a slit in my oil pressure line grommet but that didn't work too well.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-09-2014, 09:07 AM | #2 |
Re: Speedo Grommet
I ended up cutting a slit in my old speedo grommet and reusing it. Haven't had to deal with E cable or oil line grommet yet.
1967 GMC SWB 383 Stroker w/Saginaw 4sp 1979 Chev C30 Scottsdale Flatbed 350 4sp 2000 Chev 3500 Flatbed 454 Automatic 1978 GMC 6500 Flatbed Dump 366 5sp + 2sp 1965 Chev K10 LWB 230 4sp 1985 Chev K30 Flatbed 350 4sp |
09-09-2014, 01:35 PM | #3 |
Project Junkie! Fishing Poor!!
Re: Speedo Grommet
Our grommets are designed so that you can cut them and install them with hardly a trace to show you did. The original grommet has a steel clip molded into it to affix it to your firewall. Once you cut that clip it can no longer hold onto the firewall very well and looks like crap once reinstalled. My grommets seal completely around the hole in the firewall without a metal clip. So when you cut it for the speedometer cable it can still be installed and if you are careful enough you won't even see the cut. You don't even have to cut our oil pressure line grommet, because it is flexible enough to just push the oil pressure line right through it with the fitting on the end. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-09-2014, 06:06 PM | #4 |
Active Member
Re: Speedo Grommet
The E brake cable and grommet for my 1968 Restoration, I had Inline tube make a new cable for me and I sent a Grommet for them to put on as they manufactured the E Brake Cable.
09-09-2014, 07:25 PM | #5 |
Re: Speedo Grommet
Great idea for the e-brake cable. Too bad they don't make speedometer cables. WES
09-10-2014, 12:48 AM | #6 |
Re: Speedo Grommet
Thanks guys.
