Old 09-09-2014, 03:33 PM   #1
crakarjax
crakarjax's Avatar
Convert 1/4" brake line to 3/16" -- which adapter fittings do I need?
I'm ordering a 25' roll of 3/16" tubing to do my brakes and want to convert the old 1/4" to 3/16" so I can just use the same line from my roll all the way.
Anyone know which fittings I will need to do this conversion? It's for a '72 LWB coil truck with 12-bolt rear. I know that the 1/4" only goes from the master to distribution block on the diff, but have no experience with inverted flare fittings so I'm at a loss. TIA!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-09-2014, 11:05 PM   #2
min
min's Avatar
Re: Convert 1/4" brake line to 3/16" -- which adapter fittings do I need?
you can get an adapter at most auto parts stores. it has a 1/4 male end on one side and a 3/16 female end on the other side and uses the standard 3/16 inverted flare fittings. can get a picture of one for you tomorrow if it will help.
do you still have drum brakes in the rear? if so the 3/16 line may not work. drum brakes need more fluid to work than discs. could be wrong maybe someone else will chime in on that. just getting back into this after a 15 year brake and have forgot a lot.
min is offline   Reply With Quote
Old 09-10-2014, 09:28 AM   #3
crakarjax
crakarjax's Avatar
I'm only on a 3 year break and I've already forgotten a ton as well... forum posts seem to indicate that 3/16 will work for rear drums (yes I have rear drums) and anecdotal evidence is that newer vehicles with drum rears have 3/16 line to them. The pressure will be the same, with potentially lower volume. But, the lines on the axle are 3/16 anyway so I'm really not worried about it -- and I'll probably upgrade to rear discs in the future anyway.
Thanks for the tip, does that adapter nut just seal itself onto the 1/4" flare and then the 3/16" line/nut seals into the adapter nut? If so I think I know what you are talking about. I haven't checked out a parts store yet, I was trying to find everything online first in order to minimize my trips to the store.
Old 09-10-2014, 10:21 AM   #4
SHANE 73Z
If you are bending/flaring your own lines out of a coil, I would suggest getting the proper flare nuts & eliminating the adapters.
Typical flare nut sizes are:
3/8" nut for 3/16" line
7/16 nut for 1/4" line
Many of the line companies offer a 7/16" nut with the smaller thru hole for 3/16" line.
Inline Tube, Right Stuff Detailing, etc should be able to fix you up.
Shane
SHANE 73Z is offline   Reply With Quote
Old 09-10-2014, 01:04 PM   #5
crakarjax
crakarjax's Avatar
Shane
Yeah that makes sense. You mean like this one? I thought that the 3/16 line wouldn't seal correctly to the 1/4" orifice but it must if they sell that fitting.
Those nuts are expensive, I think I'll just buy the 1/4" tube after all and then I'll have a bunch of tube left over that I can use later.
Well... maybe not. haven't made up my mind yet
Old 09-10-2014, 05:39 PM   #6
SHANE 73Z
There are several ways to skin this cat.
That is what I was referring too. Once again, if your are bending your own you gotta put something on the ends anyways.
Just a suggestion, good luck.
Shane
Old 09-10-2014, 06:31 PM   #7
Mr Handy
Mr Handy's Avatar
If your going through the trouble of bending the lines, I would not skimp on the right fittings, new fitting will not seem that expensive when you have the right ones and everything is how it should be.
Mr Handy is offline   Reply With Quote
Old 09-10-2014, 09:59 PM   #8
min
min's Avatar
yes that is how it works. i tried to get the 7/16" fitting for the 3/16" line but they did not have it but said they had an adapter that would work. here is a pic of it installed.
Old 09-11-2014, 09:26 AM   #9
crakarjax
crakarjax's Avatar
Yep, you're right I'll just order the fittings and be done with it. Quick question though, I'm trying to figure out how many of the reducers I will need and I'm coming up with 4 -- does that sound right?
I have:
- 1 at the diff
- 1 coming out of the prop valve heading to the rear
- 1 going into the prop valve
- 1 coming out of the MC
Old 01-27-2015, 02:00 AM   #10
SierraMtns
SierraMtns's Avatar
I have:
- 1 at the diff
Any updates on your brake lines? How did they come out?
SierraMtns is offline   Reply With Quote
Old 01-04-2016, 11:22 PM   #11
crakarjax
crakarjax's Avatar
Hey sorry I missed your reply... I'm actually just getting to the lines now! I'll post a complete list of flare nuts when I'm done but I can tell you that I'm already a bit short. For some reason the 1/4 to 3/16 fittings I bought don't seem to fit, even though the specs say they should. These are the ones I purchased http://m.summitracing.com/parts/gar-j9011
I've also attached a pic that I found helpful.
Old 01-05-2016, 02:04 AM   #12
crakarjax
crakarjax's Avatar
Ok so the fittings I mentioned above are correct -- but they are chrome plated and so a bit big, but they fit with lube and persuasion.
My list of inverted flare fittings:
4 - 3/16 OD x 7/16-24 reducer
2 - 3/16 OD x 1/2-20 reducer
2 - 3/16 OD x 9/16-18 reducer
3 - 3/16 OD x 3/8
This covers the stock MC, prop valve, four corners and rear flex hose dist. block. Couplers and tees will just require additional standard 3/16 OD x 3/8 fittings.
All of these fittings can be found pretty cheap at advance auto
http://shop.advanceautoparts.com/p/a...2F16+7%2F16-24
http://shop.advanceautoparts.com/p/a...c-5/22190119-P
http://shop.advanceautoparts.com/p/a...c-5/22190118-P
