Suburban rear A/C install ?
I'm going to retrofit my 71sub with a rear overhead A/C unit I scored at a local wreching yard.
Does anyone have any experience running the two hoses under the chasis and up to the overhead evaporator & blowers in the rear ? Am I going to have issues running 134 such a long distance ---probably about 15 ft one way ? In other words, will my setup not be as efficient ? Should I use a "bigger" compressor / condessor ? Thanks Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry 71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster 70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges |
There is a good routing diagram in the truck assembly manual that I would suggest that you get a copy of. It shows routing, holes, clamp mountings and more.
I believe that you will need more than 15' of each hose. If I remember right it is like 24'. I can measure our hoses if no one confirms the dimension. Not sure on the compressor as we don't have the Burb back together yet. Jim |
Thanks Jim !
I have a pair of OEM hoses I took from the donor sub --- I'll have to just measure those and buy a new set.
TTT Ev
I had all new hoses made up with hydraulically crimped "O" ring fittings and eliminated the hose clamp/barb setup as I was concerned about leakage.
Jim |
