09-09-2014, 09:34 PM | #1 |
Driveshaft support bearing conversion
So, I have the donut style bearing and it's toast, I'd like to switch to the horseshoe style. I know that I'd need a new driveshaft if I were to use the front/bottom-mount horseshoe. However, I have seen rear/top mount horseshoe bearings as well. This post has pics of the horseshoe mount. CPP also sells a conversion mount as seen here.
Question -- If I use the stock style rearward mount, will that place the support bearing in the correct location (as I'm assuming the CPP mount does)? The stock mount just seems beefier to me than the dangler. And while I am here, would a 5" drop in the future be negatively impacted by this?
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 09-09-2014 at 09:43 PM. |
09-09-2014, 11:31 PM | #2 |
Re: Driveshaft support bearing conversion
I'm interested in the answer to this question as well.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
09-10-2014, 09:32 AM | #3 |
I just realized that CPP calls this a "Carrier Bearing Conversion Kit", but it has nothing to do with rearends. I think their naming is off?
1968 LWB C20 / AC / Wood Bed |
09-11-2014, 01:43 PM | #4 |
the boat guy
People commonly call center support bearings carrier bearings. If you switch to a carrier any more solid than the stock carrier bearing you have to add a slip and stub to the rear shaft.
Its much cheaper to replace with stock replacement carrier and have the shaft ballanced.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
09-11-2014, 02:47 PM | #5 | |
My only question is -- how does either bearing handle foreward and aft movement of the rear shaft due to suspension travel?
09-11-2014, 10:05 PM | #6 |
the boat guy
The original light duty carrier has a really soft rubber that is thin and allows for some fore and aft movement during suspension travel. Trailing arm trucks and large gm cars came with these carrier setups.
Anything stiffer will tear itself up when the suspension moves. Every truck with a horseshoe shaped carrier bearing has a slip in the rear shaft from the factory. From an s-10 to a kenworth. When the slip and stub lock up the carriers don't last a day.
09-12-2014, 08:57 AM | #7 | |
09-13-2014, 02:43 PM | #8 |
the boat guy
The stiff carrier at the back of the front shaft will hold the trans slip yoke in the trans. The slip on the rear shaft is for suspension travel.
09-13-2014, 05:24 PM | #9 |
What happens when the carrier bearing rubber breaks away?!?!
