Old 09-10-2014, 06:57 AM   #1
ACII
how much pressure can the corvette fuel filter handle ??
Hy all,
i would like to go with an external aftermarket fuel pump... (maybe Walbro or Bosch).
Those pumps do have up to 80 - 100 psi....
So can i use the original Corvette fuel filter ?? Can that filter handle that pressure ?
I dont wanna go with a return fuel line...
So far i got some informations out of the www the F-Bodys dont have a return line.... but i am a bit confused in my donor car (Camaro Z28 of 1999) i do have 2 fuel lines ..
I have attached a pic ...pls let me know which line goes where and what function ??
Thanks a lot
Achim
ACII is offline   Reply With Quote
Old 09-10-2014, 08:38 AM   #2
truckdude239
truckdude239's Avatar
Re: how much pressure can the corvette fuel filter handle ??
Im pushing about 85 psi to the inlet of mine
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-10-2014, 09:03 AM   #3
boostedc10
boostedc10's Avatar
The Vette filter will handle a 255 without an issue. As for what lines go where on the Vette filter its easier to explain with a picture. See below.
What is the donor engine going in?
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-10-2014, 12:41 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The filters will handle well over 100psi physically, its whether or not your actually filtering anything with that much pressure. I doubt the filter media will do anything with 100+psi straight through, but the filter/reg will have no problem handling and regulating it to the 60psi you need.
The older Fbody setups used a PWM thingy which looks and acts a bit like the 'vette style, but IS NOT the same thing. The fbody has that built into the sender/bucket. IMO its best just to keep going with your conversion using the 'vette stuff.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-10-2014, 02:49 PM   #5
ACII
thanks for help...
so i will definitly go with the corvette setup and probably walbro pump.
The engine goes into a 51 chevy pickup
CU
Achim
Old 09-11-2014, 09:46 AM   #6
Matt Cramer
Also, keep in mind that the maximum pressure a pump CAN put out often isn't what it DOES put out. It is just the pressure you'd get if you blocked the flow completely. A bypass regulator (like the one in the Corvette fuel filter) lets excess fuel go past it, so the pressure coming in is much lower.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
