Old 09-10-2014, 12:55 PM   #1
Figuarus
Figuarus's Avatar
Headlights not aligned right?
Guys, I'm wondering if I may have defective bulbs, but I cant seem to find any straight answers about this situation.
I recently replaced my headlights with Sylvania stock replacements. I noticed though, that when I switch from low beams to high beams, the pattern moves up, but also to the left, thus blinding drivers.
I was under the impression that the pattern should move up only.
Am I losing my mind?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 09-10-2014, 12:57 PM   #2
1963c-10
1963c-10's Avatar
Re: Headlights not aligned right?
Have you had the headlights adjusted?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-10-2014, 01:17 PM   #3
Figuarus
Figuarus's Avatar
Yes. Got the low beams adjusted correctly, but when you change to high beams they move up and to the left
2013 Malibu LTZ
Old 09-10-2014, 01:34 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Headlights not aligned right?
Fix 'em yourself, via Google search:
https://www.google.com/search?q=how+...ghts+&imgdii=_
Sam
luvbowties is offline   Reply With Quote
Old 09-10-2014, 01:55 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
They may have been manufactured incorrectly. Although I have a four bulb system, I had this same issue with Sylvania bulbs, which is why I don't use them anymore.
On the lamps I had, when they were manufactured the silvering process inside the reflector wasn't centered in the glass. although the bulbs were aligned with professional equipment off the nubs on the front of the lens, the light beams did not project straight out the front of the lens. I had to realign them on the garage door instead to get them close to pointing the light in the correct direction. With only two bulbs, it's probably not a silvering problem, more likely the high beam filaments are mounted incorrectly inside the lamp. I no longer trust their sealed beams, and I've never had this problem with any other brand.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-10-2014, 02:09 PM   #6
Figuarus
Figuarus's Avatar
thanks. I did think this was the case.
I knew I wasn't going crazy because I told myself so, and I always mostly listen to myself. And I Wouldn't lie to myself.
thanks for the confirmation!
2013 Malibu LTZ
Old 09-10-2014, 03:56 PM   #7
Turtleman
Turtleman's Avatar
LOL.... dang, your as bad as I am..
Turtleman is offline   Reply With Quote
Old 09-10-2014, 05:15 PM   #8
Snailed
Snailed's Avatar
Why are you using high beams with oncoming traffic anyway?
I bet you have the lights aimed too far to the left overall so the highs don't go straight ahead. Each brand is a little different but many have quite a difference L to R between beams. Lows are supposed to be biased to the right with a dark upper left corner to reduce glare for oncoming traffic. If you aim the lows so they light up the whole road you will have highs that go left.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 09-10-2014, 06:52 PM   #9
Figuarus
Figuarus's Avatar
Parts of the highways here in Salt lake are not well lit, and while driving at night, they require heavy use of the high beams
I will take a look at that. I tried to find a balanced center between the high and low beams, but when I have the low beams moved over, i can't see down the road propery. I will take some pictures here shortly and post them tonight.
2013 Malibu LTZ
Old 09-10-2014, 07:34 PM   #10
jtrichard
YES they move UP AND to the left when on high beam
jtrichard is offline   Reply With Quote
Old 09-11-2014, 12:34 PM   #11
65 C20
I agree. They move up and to the left.
What good is high beam if it doesn't increase the visibility.
65 C20 is offline   Reply With Quote
Old 09-11-2014, 11:48 PM   #12
Figuarus
Figuarus's Avatar
Ok, well if that be the case, am I supposed to split the difference?
2013 Malibu LTZ
Old 09-12-2014, 06:24 AM   #13
Snailed
Snailed's Avatar
I think high beams should be centered on the road, so slightly to the left since we drive on the right. Where the lows fall is going to be a result of how the manufacturer laid out the reflector and filaments.
Old 09-12-2014, 12:28 PM   #14
65 C20
Figuarus.
I just ran across a thread called Headlight Adjustment.
It will be close to the top of the message board.
