09-10-2014, 02:38 PM | #1 |
69-70 throttle link pic needed
Working on my 70 k5 with 350 in it ,put a 72 4bbl intake and quadrajet on it. These were off a parts 72 auto I have but the 70 is a three on the tree, anbody got a close up of the throttle linkage on the side of tje quadrajet? I cant find a pic in my service manual or do i need an overhaul manual?
09-10-2014, 06:20 PM | #2 |
Re: 69-70 throttle link pic needed
I'm not sure this will help, Brian. The picture is of my 69 2wd, with a TH400 and 350. I know, at minimum, you need to ignore the downshift switch and bracket to actuate the switch.
If nothing else it'll take your post back to the top. Jim |
09-10-2014, 09:47 PM | #3 |
First is a pic of a rod and not a cable it would look the same pretty much.
Here's mine just doesn't have the cable connected. |
09-11-2014, 03:12 PM | #4 |
You have a clearer picture (lighter) and do you have one at the accelerator pedal as well? What year is your truck Tree 50?
09-11-2014, 03:20 PM | #5 |
Is it safe to assume your 70 still has a rod from the firewall to the carb? The change to cable was made in 71.
09-11-2014, 05:58 PM | #6 |
Yes, i pulled it off a 69 i have for parts, but the 69 is an automatic and a 2bbl but i did use the rod.
09-11-2014, 07:46 PM | #7 | |
Mine is a 68, pulled throttle cable and whole pedal assembly from a 77. |
09-11-2014, 08:30 PM | #8 |
Does your carb linkage look like Tree-50's? If so, maybe you could take a dremel or die grinder and remove the stud that holds the cable on a 72? Then drill it out if nec. for your rod style linkage.
Otherwise, put on the cable. You can get a carb adaptor at the u-pull-it off another quadrajet that has a cable, if you didn't get the one off the 72. That also opens the door for a down-shift cable if you decide to go automatic in the future. It's a better way to go if your motor mounts break, there is less chance of the throttle getting stuck. |
