Old 09-10-2014, 05:08 PM   #1
FlameOut
3 on the tree shift lever
I reinstalled my steering column today, along with linkage rods to trans, but when I installed the shift lever, I'm only able to go into two gears. Not sure if it's 1st and rev or 2nd and 3rd. (Truck currently not drivable)
Just wondered if there is some trick I'm missing. I guess there must be a spring in there, that keeps the lever forward in the 1st/rev position and then yiu need to push slightly when going up into 2nd?
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 09-10-2014, 07:11 PM   #2
zosoppp
Re: 3 on the tree shift lever
I think (new to this myself) that the default position is forward in between 2nd and 3rd and you have to pull the handle back (towards driver) to get between 1st and reverse.
zosoppp is offline   Reply With Quote
Old 09-10-2014, 08:16 PM   #3
70shortstep
Registerd User
70shortstep's Avatar
Make sure both levers are in neutral. I ran in to a similar issue hooking mine up. If only one lever is moving, be sure it is in neutral before you try to move the other.
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
Old 09-10-2014, 09:32 PM   #4
Tree-50
It is already forward and you pull to rev and 1st.
Like already stated, make sure they're in neutral on the tranny too, you can click it with your hand. Make sure they're level as well and that little middle finger guide thing can move back and forth freely engaging either rod with your finger under the hood. Even just a little off and it'll snag and get stuck in gear.
Tree-50 is offline   Reply With Quote
Old 09-10-2014, 11:34 PM   #5
FlameOut
I'll try disconnecting the linkage to see if it will shift properly. I have the trans in neutral, and I can manualy move both levers on the column to get all 3 gears and reverse. Just can't do it from inside the cab with the column shift lever
1967 Chevelle SS
