Old 09-10-2014, 05:55 PM   #1
biohazardbill
Brake Line setup
I have purchased big brake kit front and rear for my 65 Suburban which have multi piston calipers. I have a new disc/disc master cylinder and prop valve.
So my question is about line sizes, I plan on making my own lines.
Should I run dual 1/4 inch lines from the M/C to the prop valve.
Then 3/16 to each side on the front to 3an Flexible lines
and for the rear run 1/4 to a 4an line to the T on the rear axle and split off 3/16 there to each side on the axle?
Thoughts/suggestions?
biohazardbill is offline   Reply With Quote
Old 09-10-2014, 08:03 PM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: Brake Line setup
3/16 everywhere the whole thing to # 3 flex lines. Do you mean adjustable prop valve? Do you have the right size master? What calipers are we talking about? Power or manual?
CHRIS67GMC is offline   Reply With Quote
