Old 09-10-2014, 06:48 PM   #1
rdgt67
3 on the tree
Unusual problem. When I align the 3/16 pin in the slots and adjust the linkage it puts the column lever too far down and hits my leg. If I rest the pin on the column slot and push it through the actual lever holes then adjust the linkage the column lever is fine. Any comments? I did read the article that most folks point you too but it doesn't address this issue.
rdgt67 is offline   Reply With Quote
Old 09-10-2014, 08:28 PM   #2
70shortstep
Registerd User
70shortstep's Avatar
Re: 3 on the tree
Loosen the brackets that hold the column and twist the whole column
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
