Old 09-10-2014, 07:01 PM   #1
83 Silverado
83 Silverado's Avatar
Welding v-bands on truck manifolds
Looking to see if anyone has modified a set of truck manifolds from flanges to v-bands. I'm mostly looking for info on the weld of it, and if its something that needs per and post heating like older cast iron manifolds.
83 Silverado is offline   Reply With Quote
Old 09-10-2014, 07:12 PM   #2
boostedc10
boostedc10's Avatar
Re: Welding v-bands on truck manifolds
I have done them with no pre/post heating. The LS manifolds are like a cast steel and actually weld pretty easily.
Way easier than an old cast iron manifold!
I know Wasted Income has also welded some vbands on his. Maybe he will chime in.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-10-2014, 07:23 PM   #3
tinydb84
tinydb84's Avatar
I read a bunch of threads on LS1tech because I am going to do mine (eventually)
Without pre or post heat it was a mixed bag. Some people had them crack some didn't. Everyone that pre/post heated didn't have them crack. I plan on pre post heating mine when I get around to it.
David
Instagram: myfabguy
Old 09-11-2014, 12:04 AM   #4
softballnrd27
Always a work in progress
softballnrd27's Avatar
I pre and post heated, mig-welded and I haven't had any issues.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-11-2014, 11:01 AM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
I preheated mine, and they've been perfect. I agree with boostedC10 that they weld more like steel than iron....it's like GM knew what we'd be doing to these poor engines...lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 09-11-2014, 12:26 PM   #6
mister twister
mister twister's Avatar
i cut my flange and rotated it to fit the frame rail on the driver side. Gave it to my buddy to take to work where he could preheat it and weld it with inconel filler. When he gave it back he said he welded it with mild steel and i'm not sure he even had to preheat it. I have been driving the truck for over a month now (heating and cooling) and not had an issue knock on wood!! If that was truely the case i could've done it myself with my MIG..
mister twister is offline   Reply With Quote
Old 09-11-2014, 01:47 PM   #7
Wasted Income
Boosted Member
I was able to weld a stainless elbow to the manifold to avoid the master cylinder, and it's been holding up great, through much abuse.
Turbo diesel
Old 09-11-2014, 08:04 PM   #8
83 Silverado
Thank for the info guys, it's looking like per and post heating is the way to go but what are you using to heat them? If your using a oven I can only imagine the GF's reaction if she fond my cooking car parts lol.
Old 09-11-2014, 08:30 PM   #9
tinydb84
tinydb84's Avatar
I plan on using my oven hahah. I have seen people welding cast iron use BBQ's, Fire pits, OA torches, etc. Then either let the fire die down or wrap the part in a welding blanket and cover it in sand.
David
Instagram: myfabguy
Old 09-11-2014, 09:55 PM   #10
LS1Impala
I MIG welded my manifolds without pre/post heating and they have held up just fine. Ive got over 5k miles on my build now.
1968 C10 5.3/4L60E LS6 cam and a 3600 stall
1968 Camaro 6.0/4L65E T76 turbo 9"
1960 Impala LS1/4L60E all stock cruiser
LS1Impala is offline   Reply With Quote
Old 09-15-2014, 09:01 AM   #11
Wasted Income
Boosted Member
My wife gets a little pissy when she comes home to car parts in the oven.
Turbo diesel
Old 09-15-2014, 09:10 AM   #12
Jon01
Jon01's Avatar
Yours does that too?
I tell ya...some women!
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 09-16-2014, 10:49 PM   #13
BigRed76
BigRed76's Avatar
Is there a specific temperature range that the manifolds need to reach for the pre/post heating?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-17-2014, 12:38 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
just take a rosebud torch and heat the general area for 5-10 minutes before welding. I'd say your in the 4-500* range. Most guys I know that do them in the oven set the oven to "clean " which is max or usually 500*.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-17-2014, 08:31 AM   #15
BigRed76
BigRed76's Avatar
Thanks. I figured they'd probably have to be pretty hot.
Zach
