Old 09-10-2014, 09:28 PM   #1
Houston Ben
Houston Ben's Avatar
Questions about radiator/engine flush and running water or coolant
Hi all,
After messing with my new intake for a/c and such I realized I hadn't changed over to coolant yet so I have a few questions.
!. Can I run just tap water? This is what I have been running and seems to work and cool fine.
2. If NO to #1, what is the best method to flush the radiator and engine of all the brown water without using harsh chemicals or taking it somewhere?
Any other words of wisdom?
Thanks!
Houston Ben is offline   Reply With Quote
Old 09-11-2014, 01:22 AM   #2
Xeen
Xeen's Avatar
Re: Questions about radiator/engine flush and running water or coolant
To flush the cooling system of most impurities I would use the slow water change out method.
Open up the radiator drain valve all the way.
Open the fill cap.
Let the radiator drain until empty then close the valve and refill with water.
Replace the fill cap.
Start the engine and let run until normal operating temps are reached then shut off and let cool for 10 min.
Drain the radiator again, then refill with water.
You get the idea here, do this 5 times.
Then drain the radiator one last time and add 100% coolant, read the container and make sure it is not the 50/50 water/coolant mix.
DO NOT open the radiator drain valve and put the hose in the radiator and fill with fresh water and just let the engine run or you may blow a head gasket.
Patience is the key here you don't need to get in a hurry and risk damaging your engine.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-11-2014, 07:18 AM   #3
truckdude239
truckdude239's Avatar
You should never run tap water.... there are chemicals in that will erode the inside of cooling system. Destilled water or coolant. Remenber coolant has a higher boiling point.... and a quite lower freezing point
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-11-2014, 08:26 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If your only ! I mean only trying to flush it out, then tap water should be fine, HOWEVER as TruckDude said, never use tap water for cooling your engine, especially one with aluminum heads.
The LSX engines hold air if emptied, so you should jack it up in the front when filling for final time AND fill the engine first with your coolant\distilled water mixture.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-12-2014, 02:39 PM   #5
corndoggydogg
corndoggydogg's Avatar
I just performed a full flush on my system using one of those Preston flush kits. It worked well and a lot of gunk came out. However, I just realized that there is still a bunch of water (I figure 2 gallons) sitting in the engine block that won't come out. So after adding the 50/50 mixture, I figure the true effective mixture is now only 75% water/25& antifreeze. I tested the liquid and it is not giving me any freezing protection.
My original thought was to reflush the system, and this time, remove the coolant plugs on the engine to fully drain the system. Then refill with 50/50 again. But...I can't get the plugs out.
Reading through this thread (and now doing some reough math), it sound like the best (and easiest) course of action is flush, drain as much as I can though the radiator, and refill with 100% antifreeze.
Does that sound like a good plan? This is my first time doing this to this truck. I just purchased it and have a feeling it has been neglected for many years. So I really want to do the right thing here and return her to all her deserved glory.
Also, does anyone recommend replacing the t-stat at the same time as this flush? Just a thought.
Any feedback would be greatly appreciated.
Thanks!
corndoggydogg is offline   Reply With Quote
Old 09-12-2014, 04:09 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Questions about radiator/engine flush and running water or coolant
My suggestion is to take the old thermostat out and replace after you have gotten all the old water and gunk out.
To get almost all of it out jack the rear of the truck up high enough so when you take the hose off the water pump it will drain almost every drop of water out of the block. Have the thermostat out of it when you do this.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-13-2014, 12:30 AM   #7
BigDan3131
BigDan3131's Avatar
Another way to help remove the water is to use air pressure to force the water out, just don't go crazy on the pressure.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
