Old 09-12-2014, 12:19 PM   #1
paulbrgr9999
drum to disk swap alignment question
My 70 c20 is getting disk brakes next week. The doner is a 72 c20.
1. How far can I drive the truck without an alignment?
2. When the alignment is done do I use the alignment spec for a 72 or a 70?
The repair manual I have states that the toe in for 70 should be
1/8-1/4. For 72 it states exactly 3/16.
thanks,
paul
paulbrgr9999 is offline   Reply With Quote
Old 09-12-2014, 03:19 PM   #2
spatz
Re: drum to disk swap alignment question
Hey Paul, you should get an alignment as soon as possible. Are you changing just the spindle assembly, I believe you will need the drag link from the doner. maybe somebody will chime in. I'm not sure on the C20's but on the C10's you have too due to different tie rods.
spatz is offline   Reply With Quote
Old 09-13-2014, 12:14 AM   #3
paulbrgr9999
What the heck is a drag link?
thanks
Old 09-13-2014, 01:09 PM   #4
BlackedOut67shorty
BlackedOut67shorty's Avatar
Drag link is the center link that connets to both tie rods and is held in by the idler arm and steering arm, yes you need that from the doner
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 09-13-2014, 02:09 PM   #5
paulbrgr9999
Thanks,
I took everything from the doner except the crossmember. So my 70 crossmember is identical to the 72 I hope? Any comments on that?
paul
