Old 09-12-2014, 12:33 PM   #1
NC67Chev
NC67Chev's Avatar
Front brake line
A few years ago, I changed all of my rotten brake lines out. The lines I went with were stainless. I recently changed to disc brakes on the front using the same lines. The brakes work great, but I'm having issues getting one of the flares to completely seal. In any case, I'm to the point of making a new line from the prop valve to the front tee fitting. The prop valve I used is one of the universal ones that have 2 separate ports for 3/16 lines to the front. I plugged one port and used an adapter to on the other one to step back up to 1/4 line, which goes to the front tee fitting and then steps down to 3/16 to each front wheel.
My question is this....Am I going to create any issues with using 3/16 line from the prop valve to the tee? It would be nice to eliminate the adapter if possible, but I can live with it if there's a reason not to do it. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 09-12-2014, 02:29 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Front brake line
Using 3/16 line all the way will work fine....
LockDoc
Leon
Old 09-12-2014, 02:37 PM   #3
NC67Chev
NC67Chev's Avatar
[QUOTE=LockDoc;6840355]Using 3/16 line all the way will work fine....
Thanks! I didn't want to redo the line only to find that my front braking went to crap
