I finally got my tach dash installed but i found out the gas gauge does not work as well as the right side lights and the right blinker does not work. im guessing the circuitpanel on the right side is bad. who has the best price on the circuit board for a circuit board for my tach dash
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! ![]() ![]() 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it ![]() ![]() ![]() ![]() |
also what color on the 2 wires did they use on the tach hook up?
------------------ 1969 cst swb 350/400 th DANNY C. ddclux@aol.com st. louis mo. for pic.s go to http://community.webshots.com/user/dandeluxeGO TO Fotki. com for public pic.s under DANDELUXE
Red and Brown for the wires ... thats the colors.
Check the continuity with a meter from the wire harness plug location to the light socket locations... maybe you got some breaks in the circuit.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
ROD, THANKS ILL TRY THAT. ITS GOOD TO BE BACK
Did you put all the screws that hold the circuit panel and made sure you all of them were tight . I left one loose and all kinds of weird things were happening. It wasn't grounding properly .
