Gas tank and sending unit help..
I'm wanting to order a new Gas tank and sending unit for my 1986 Chevy C10, V6 4.3L.. I only have 1 tank on the drivers side.. I've looked on the Haynes repair manual with no results on if I have a 16 or 20 gallon tank or a 2 or 3 hose plug sending unit.. I think my truck has a 3 hose plug sending unit and a 16 gallon gas tank.. Can anyone confirm this I don't want to order the wrong stuff..
Will I ever finish my 1986 stepper.. |
#2 | |
Re: Gas tank and sending unit help..
Longbed = 16 or 20 your choice I would think you have hoses you can probably take a quick look underneath and see. 1 supply,return, and vent.. Looks like a step side... Short bed so i would put my money on 16g |
I took a look underneath and there appears to be 3 hard lines going to the tank.. So I'm pretty sure it's a 3 line sending unit.. Thanks for yr help
If it has TBI,it should only have 2 lines,and an in-tank fuel pump.
If it has a carb,and an engine-mounted pump,it should have 3 lines: 3/8" supply,5/16 return, and 1/4" vent line . Usually,the stepsides,and SWB trucks had a 16gallon tank.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
Thank you sir..
#6 | |
Moderator
![]() Join Date: Oct 2008
1973-1986 gasoline I6, V6, & V8 were ALL carburetor engines. The stock 1986 V6 should have an R4M4MED or R4M4ME Rochester Electronic Quadrajet with a mechanical fuel pump, a return line, and a 3 line sender. All senders have vents but there were some trucks in the 70s that had 2 line senders with vent, feed, and no return line. GM added the return line to mitigate vapor lock. By 1986 they all had return lines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
78K & 79C Jimmys
both my 78s have two line pumps,both 79s have 3 lines,might be the year it changed...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
