Old 09-12-2014, 09:43 PM   #1
collins10672
collins10672's Avatar
1964-66 chevy and gmc over the windshield rust repair panel
I just happened to be looking around the web last night and found the 1964-66 front inner roof panel (over the windshield) repair panel.it is a new reproduction and I thought I would pass this info along to everyone.autobody specialties carries this panel.i am not endorsing nor do I work for them.i just ran across the panel and thought I would pass it on.i know this is a tough area to repair and maybe this panel will help put some of the rougher cabs back on the road.thanks
collins10672 is offline   Reply With Quote
Old 09-13-2014, 06:11 PM   #2
spacedebris
Re: 1964-66 chevy and gmc over the windshield rust repair panel
here is the link if anyone is interested. http://www.autobodyspecialt.com/cgi-...on&key=C-182-1
spacedebris is offline   Reply With Quote
Old 09-14-2014, 09:19 AM   #3
hemifalcon
...that would have been a nice piece to have...(before now..)
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 09-14-2014, 03:37 PM   #4
ls60apache
I agree 2 months ago a good portion of that panel can be used for 60-63s
ls60apache is offline   Reply With Quote
Old 09-14-2014, 07:02 PM   #5
PGSigns
PGSigns's Avatar
The one for the outside above the windshield would be a great one to have. Around here it would save a bunch of cabs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-14-2014, 07:54 PM   #6
RANDY COX
RANDY COX's Avatar
That's good to know.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-14-2014, 09:29 PM   #7
ls60apache
Jimmy
they already make that one its been available for some time now.it fits pretty decent.
Old 09-14-2014, 11:58 PM   #8
collins10672
i think the cause of the rust over the windshield is from the caulking going bad around the drip rails letting water in between the panels holding moisture and never really drying out causing the rust.it also doesn't help that the metal between the roof panel and the headliner panel is bare steel on the inside.
Old 09-15-2014, 08:09 AM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
That is one reason but a lot of the trucks sit in a field or barn, mice get up in there and build nests, then urinate in the far side of the nest when its cold. this is why the inside would rot and not the outside on some.
Either way, this is a good piece for saving some cabs!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-02-2015, 07:23 PM   #10
russellrox
Would this panel work for a 60-63 cab also, anyone have any experience repairing this area.
russellrox is offline   Reply With Quote
Old 02-02-2015, 10:32 PM   #11
billye1982
I need an outside one above the windshield too. I will take a look!
billye1982 is offline   Reply With Quote
Old 02-03-2015, 01:24 AM   #12
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I haven't used this panel, but have looked at it for interchange, the inner panel ha a little different shape at the roof pillars, but along the top of the windshield it appears to be the same. since you are going to be in there cutting/welding I don't see where you couldn't make this work on the early cab.
as far as I can tell the outer piece is the same 60-66
Old 02-20-2015, 12:41 AM   #13
russellrox
nobody has used this on a 60-63 cab yet, I just bought this panel today so will see what it looks like in a few weeks, if anyone has used this panel and knows what needs to be changed to make it work.
