Old 09-12-2014, 10:19 PM   #1
dwcardfan
dwcardfan's Avatar
What pump to use in a 87 factory tank?
I am helping a buddy with his build on a 1982 chevy that he will be putting a 2003 5.3 and 4l60e. He wants to use a 87 factory tank and sending unit but replace the pump with a high pressure in tank pump. What pump would be the best to use?
Thanks for the help!
dwcardfan is offline   Reply With Quote
Old 09-12-2014, 10:50 PM   #2
dec010974
dec010974's Avatar
Re: What pump to use in a 87 factory tank?
Hello. If i remember correctly, 1987 c10 square bodies have a TBI fuel injection. If that's the case the ac delco ep381 pump should be easily swapped for the TBI fuel pump. Good luck.
dec010974 is offline   Reply With Quote
Old 09-12-2014, 11:39 PM   #3
dwcardfan
dwcardfan's Avatar
Thanks for your help dec
Old 09-13-2014, 09:57 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What pump to use in a 87 factory tank?
If the tank already has a intank pump just buy a replacement pump for the motor the truck came out of and install it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-02-2014, 12:35 AM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
A TBI truck motor pump runs at what psi 16? I used
the pump mentioned above.. Think the application was a tuned port corvette
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-02-2014, 08:12 AM   #6
truckdude239
truckdude239's Avatar
ac delco ep381 IS WHAT I USED IN MY 80 SUBURBAN TANK
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-04-2014, 09:27 AM   #7
solidaxel
solidaxel's Avatar
I just went to the parts store and ordered a in tank pump for a 2003 Camaro with a V-8
Works great. maybe it was the same as the EP381, did not save the box!
It fit the 87 small tank 16ga. and the sender was for the 87 also and now I have a working gas gauge!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-04-2014, 04:12 PM   #8
dwcardfan
dwcardfan's Avatar
Thanks for the help guys. We just put a walbro 255 on the 87 sending unit. I just had to solder the wires because it had a different plug. Other than that it fit great. We also put a new 87 tank in his truck to have the baffles. Total I think he spent around $240 for new tank, sending unit and pump.
