Old 09-12-2014, 11:58 PM   #1
SierraMtns
SierraMtns's Avatar
Smile Rethinking future LS swap
I am planning on doing an LS swap in my 67 stepper down the road and really want to do a LQ4 or LQ9. But now I am rethinking the build.
The guys over at Powder Nation show what can be had out of a junk yard 4.8. Man was I impressed. My SBC 283 cant even get close to those numbers.
Here are the videos.
#1.
http://www.powernationtv.com/episode...ls-tech-part-1
#2.
http://www.powernationtv.com/episode...ls-tech-part-2
Enjoy
SierraMtns is offline   Reply With Quote
Old 09-13-2014, 10:13 AM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Rethinking future LS swap
The base LS engine is pretty much the same engine for whatever size you buy.
The power they make stock is way better than the old short blocks ever thought about being.
Look at it like this. If the 4.8 can do that what would the LQ9 do with the same mods?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-13-2014, 03:26 PM   #3
crazy longhorn
Fabricate till you "puke"
Nice read, bro! I have also been looking @ the 6.0? My 69 runs a 5.3 (carbureted)...man ,she is a sweet ride! Bigger, is always better tho? Build it , with the 4.8.....then drop that .030 over 6.0....a little cam+ head prep/camshaft. Now you are knockin on the 500 HP door. That big mill, will pull it from way on the bottom? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-14-2014, 01:26 PM   #4
SierraMtns
SierraMtns's Avatar
Yeah I have always wonder if bigger is better too? I have seen some 5.3 with a little work make some big numbers.
How much power do we need to have in our C10 to make them really move?
Old 09-14-2014, 03:16 PM   #5
Super73
Super73's Avatar
That is a loaded question.
I started with a forged 347 with some bottle.
Now I have a 418" with even more bottle ability. Should have enough power to go in the 8's at more than 150mph once sorted out.
Yet I have twin 67's that might find there way on the truck making even more power requiring even more safety stuff than I have today.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-22-2014, 10:50 AM   #6
mattcrp1
mattcrp1's Avatar
Those are great videos. I have always wondered what a 4.8l build up was capable of. It seems like people often over look these and go straight to a 5.3l or 6.0l. It was very well thought out and had a couple of good tips for doing some of the upgrades. Thanks for posting that.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
