09-13-2014, 12:34 AM | #1 |
_Ogre, calling _Ogre
Hi, is this your truck?
09-13-2014, 10:59 AM | #2 |
Re: _Ogre, calling _Ogre
No, that is his truK
GOD BLESS AMERICA! |
09-13-2014, 11:33 AM | #3 |
maybe
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-13-2014, 03:52 PM | #4 |
could be mine!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
09-13-2014, 06:18 PM | #5 |
ok, ok, I get it.
but the real question: what is that fluid reservoir on the firewall? I'm wanting to run a dual master with hydraboost off the stock bracket and use the stock pedal. I have the aftermarket M/C mount for the dual M/C but adding in the booster whether vacuum or hydraulic is going to push the M/C back under the front of the bed. Not real convenient for adding fluid. I need some kind of small reservoir like that, run a tube down to the M/C. I'm thinking to braze or weld a fitting to the top of the M/C cover. |
09-13-2014, 11:33 PM | #6 |
09-14-2014, 12:57 AM | #7 |
Thanks mr48chev, just what I needed.
Found this on a F* forum, looks like what I want. functional, no pizzaz. OP there sez it's off a 95 Nissan Quest, whatever that is. He found it on ebay. Now let's see if the pics show up. They're on a F* forum, can't really be expected to work right. Last edited by tmoble; 09-14-2014 at 01:03 AM. |
09-14-2014, 08:14 AM | #8 | |
09-14-2014, 09:01 AM | #9 |
https://www.google.com/search?q=Volk...iw=918&bih=498
This is great, who sells it?? auto-x.org seams to be a magazine |
09-14-2014, 09:57 AM | #10 |
Sorry about my last post. A little more explanation is in order. I have the speedway power brake system in my 57 and the vacuum booster and master cylinder are under the cab. The only way i can check the fluid is crawl under, take the cover off and stick my finger into the cylinder.
This is the url for the auto-x.org master cylinder cover and resevior http://auto-x.org/master-cylinder-re...y-ford-wziqwa/ Where do I get one? |
09-14-2014, 11:29 AM | #11 | |
Hollister Road Co.
09-14-2014, 11:29 AM | #12 | |
http://www.ebay.com/itm/like/261461194286?lpid=82 Kim |
09-14-2014, 01:30 PM | #13 |
you probably have a corvette style mc on the speedway kit
the kit you have linked to should work just make sure before ordering truk uses a o3 mustang hydroboost setup with a plastic tank same setup the factory5 kit cars use, i found the remote reservoir info on the factory5 forum i used the nissan quest reservoir and the adapters, pull the tank out and insert the adapters then ran teflon hose to the reservoir
