Old 09-13-2014, 10:35 AM   #1
Tzclark
Tzclark's Avatar
Smaller brake booster
I thought I was going to have a problem with fitment but didn't want to cross that road until it was a problem for sure. My booster fits but doesn't allow the removal of the valve cover. I am running the tall Chevrolet big block covers and my motor is solid lift so the covers will have to come off for setting valves once a year. What are you guys running for smaller booster that's budget minded?
1972 Chevy shortbox, done up 396bbc
1968 Plymouth Roadrunner, 1000hp twin 72mm turbos
2017 F350 Lariat, 6.7, stock except leveling kit and larger tires
2014 nissan pathfinder sl (the kid hauler)
Tzclark is offline   Reply With Quote
Old 09-13-2014, 07:02 PM   #2
motorcritter
motorcritter's Avatar
Re: Smaller brake booster
Hydro boost would give you more room, and you wouldn't have to be concerned about engine vacuum issues and great braking performance.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 09-13-2014, 09:22 PM   #3
Fitz
Attachment 1301102
A 7 inch diameter dual diaphragm booster will give you lots of room. Don't know what cam you're running but Stainless Steel Brakes has a vacuum pump if your vacuum pressure is below 14 in. That's what I run.
Fitz is offline   Reply With Quote
Old 09-16-2014, 01:06 AM   #4
Tzclark
Tzclark's Avatar
Thanks guys, I'll look into those options. That 572 sure is pretty!
Old 09-16-2014, 11:21 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Smaller brake booster
I just picked one of these up a few weeks ago. Haven't had time to install it yet though! Got the brackets and rods with it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-09-2014, 08:33 PM   #6
OrangeCrush1970
OrangeCrush1970's Avatar
I just ran into this same problem on my big block swap. What are the part numbers for the 7" brake boosters?
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 11-09-2014, 08:37 PM   #7
OrangeCrush1970
OR, will the brake booster from a corvette work??
Rottenwood Garage
2 Tons of Fun
Old 11-10-2014, 11:09 AM   #8
Sammy
Running the smaller boosters really cleans up the compartment. The only problem like stated above is if the cams not providing enough vacuum to operate properly. Ebay n most of the booster manufactures have plenty to choice from. On my stockish 350 works well with the smaller version.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
