09-13-2014, 01:49 PM | #1 |
15x6 6 Lug Stock Steel Wheels-4
*********** SOLD to DPowers 10/17/2014 ****************
Set of four 15x6 stock steel wheels. 6 lug, 5 1/2" bolt circle, 3 1/2" hub diameter, 4 nubs for stock hub caps, 3 1/2" backspacing, 0" offset. All four are stamped "K-1-7 5 24 AX" which means Kelsey-Hayes, Romulus, Mi plant, 1967, May 24, AX Application Code. Excellent condition. No rust or dents. Perfect for an original 1967. All four look exactly like the pictures. Tires are P215/75R15, Firestone FR440. Tire tread is good but age is unknown. They have cracked sidewalls. I consider them scrap, or perhaps only for usage as a spare. I can demount and scrap them if you want before shipping. $125 for the set. Shipping is probably about $25 each. Last edited by VictoriaHardware; 10-17-2014 at 08:18 PM. Reason: sold |
09-13-2014, 03:00 PM | #2 |
Re: 15x6 6 Lug Stock Steel Wheels-4
How far are you from the Ohio border?
09-13-2014, 04:09 PM | #3 |
zip 48383
09-19-2014, 08:49 AM | #4 |
Are these sold?
09-19-2014, 11:06 AM | #5 |
Dang i just need one of those
1967custom |
09-19-2014, 12:41 PM | #6 |
Still for sale
09-25-2014, 11:30 AM | #7 |
i cant tell from the photo are they disk brake wheels?
09-25-2014, 11:51 AM | #8 |
No- they have 3 hubcap nubs
09-25-2014, 12:47 PM | #9 |
hmm, I just went out and the two on my 66 panel are three nub and have the sloped back side indicating they are drum brake rims. the more i look at the pic it appears yours are disk brake rims. could you get a better pic of the back? thanks Ben
09-25-2014, 01:05 PM | #10 |
I would do $80 for rims only with local pick up
09-25-2014, 01:16 PM | #11 |
67-72 parts collector,…
Picture shows 4-nub wheel.
Or is that an incorrect picture?
09-25-2014, 11:51 PM | #12 | |
I will take them if they are as originally described and pictured. |
09-27-2014, 10:47 AM | #13 |
Sorry guys, got mixed up. They ARE 4 nub.
DPowers- they are as described. They are yours. Are you thinking pick up or ship? With tires or not? |
09-30-2014, 08:35 PM | #14 |
PM returned
09-30-2014, 11:04 PM | #15 |
'67 yom wheels are not designed to clear the db caliper, regardless of nub count. $125 a great deal anyway, wish I needed a set!
09-30-2014, 11:10 PM | #16 |
I don't know the "date code" system,... but how do you know they aren't 1977 or 1987 wheels?
10-14-2014, 06:56 PM | #17 |
These wheels were only available in the 60's, so must be 1967.
I have another set of K-H steel wheels that were available in the 70's and 80's. The ones made in the 70's are stamped "5" for 1975 and the ones from the 80's are stamped "85" for 1985. |
