Old 09-13-2014, 05:26 PM   #1
1tuff71
1tuff71's Avatar
12 bolt got wet
I just had the seals and bearings go out on my 12 bolt and found a bit of rust inside the tubes and also the bearing cage was rusted out ( hard to believe ). Gears seem to be ok but the axle seals and bearings are toast. Without seeing it is this diff worth saving or should I be looking for a new (used) one.
1tuff71 is offline   Reply With Quote
Old 09-13-2014, 07:31 PM   #2
Mike C
Mike C's Avatar
Re: 12 bolt got wet
I responded to this in the Blazer section. Please don't cross post...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-14-2014, 11:33 AM   #3
1tuff71
1tuff71's Avatar
Re: 12 bolt got wet
Sorry but I posted here after thinking I'd put it where it belonged. Thanks again
