09-13-2014, 08:09 PM | #1 |
Where does the HEATER HOSE RETAINER CLIP go ?
My 70 C-10 350 with factory AIR CONDITIONING, doesn't have the heater hose clip pictured below. Were they only on NON air conditioned trucks or is mine just missing ? If it's missing, can somebody post a picture of exactly WHERE it goes ? ( does it clip to the fender well ( like some cars do ) or is it just a " clamp " to hold the two hoses together ? ) THANKS for your help !!! . . . . |
09-13-2014, 08:14 PM | #2 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: Where does the HEATER HOSE RETAINER CLIP go ?
Steve there shoud be a square hole in your inner fender for the clip to fit into.
09-13-2014, 08:26 PM | #3 | |
THANKS !!! . . . I couldn't find any holes in my inner fender . . . . . . the inner fender IS a reproduction, so they probably didn't bother with the square hole !!! Maybe someone can post a picture so I can " engineer " a square hole ???? |
09-13-2014, 08:34 PM | #4 |
Yup it attaches to the inner fender. Here some pics from my 72
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
09-13-2014, 08:36 PM | #5 |
Another
09-13-2014, 08:37 PM | #6 |
Last one
09-13-2014, 08:39 PM | #7 |
That's interesting !!! The only picture I have saved of one on a truck with A/C shows it just clamping the two hoses together. There isn't a lot of room with the A/C valve on top of the inner fender. Where should it have attached in the picture below ? . . . . |
09-13-2014, 08:43 PM | #8 |
Oops I didn't read the whole post. My bad. I do not know if it attached to the inner fender on not on trucks with A/C. I have only seen them attached to tye inner on NON-A/C trucks.
09-13-2014, 08:50 PM | #9 |
After looking around I found this pic. You can see the clamp and that it DOES attach to the inner fender on trucks with ac
09-13-2014, 09:38 PM | #10 |
Steve there are two types of clamps. One that like pictured is on non a/c trucks, and the second type actually is held in place by one of the heater water valve screws ( the front one, nearest the rad.) and the 3/4 line runs across to the water pump while held by a strap clamp located on the front of the a/c pump.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
09-13-2014, 10:41 PM | #11 |
Moderator
On my 68 with AC, the clip shown in your first pic is present. It pops through a hole on the inner fender as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-14-2014, 12:19 AM | #12 |
Yes Blue it is attached in that picture, but assuming the picture is of your blue 72, that is not a factory water valve and the retainer was likely re-located when the heater valve and hoses were replaced and repositioned.
Also, the vacuum pod is metal, my 72 had a plastic one from the factory. I'd much rather have that metal one. Side note: A/C hoses re-done as well. Last edited by mechanicalman; 09-14-2014 at 12:19 AM. Reason: line delete |
09-14-2014, 02:41 AM | #13 | |
09-14-2014, 10:14 PM | #14 | |
09-14-2014, 11:46 PM | #15 | |
Seems we agree on 72s. Nice info, however, on the early models thanks. |
09-15-2014, 08:24 AM | #16 |
I was surprised to see the clamps on the A/C hoses. I thought they must have been replaced. Does your A/C hold a charge and function correctly?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-15-2014, 04:38 PM | #17 | |
It's amazing how many changes were made to these trucks from 67-72. The mechanical and accessory changes, in my opinion, were far more numerous and significant than the visual design modifications. The 69 Service Manual clearly shows the A/C and heater hose routing and clamp type A/C hoses on page 1A-29 including the clip that sparked this discussion. I suggest that O.P. and anyone else interested check their year's Service Manual to see what it shows. Last edited by FirstOwner69; 09-15-2014 at 04:53 PM. |
