09-14-2014, 07:55 PM | #1 |
Old member
Question for all of you
I bought this setup at our truck clubs first picnic a few weeks ago. I should be able to bleed the master cylinder and mount it and then hook my lines up bleed the lines and be good to go. I don't think I'll use the valve since it doesn't have the hook up for the brake lite on the dash. Mine still works. Shouldn't take long at all I don't think and the new look will be well worth it!
09-15-2014, 02:16 AM | #2 |
Re: Question for all of you
What's the question?
09-15-2014, 07:29 AM | #3 |
Yup-my question too!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-15-2014, 08:49 AM | #4 |
I don't what the question is either but.....The white knob on the proportioning valve is the centering tool, when done with the install the brake light sensor goes there.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-15-2014, 08:55 AM | #5 | |
Old member
The question!
Does anybody see why this shouldn't work like I stated. Just bleed the cylinder and lines and done. I just don't want to get my stuff off and findout this stuff want work. Im not going to use the valve unless I can figure out how to hook my dash brake light up to it. Quote:
Does anyone have a website to explain this knob?
09-15-2014, 08:59 AM | #6 |
It just holds your valve in the right place(center) while bleeding to make things easier. When your finished bleeding you pull the device out (keep it for later use) and install your existing switch. That switch goes to your brake light on the dash.
09-15-2014, 11:13 AM | #7 |
Old member
Cool thanks. I asked the guy I bought it from but he wasn't to sure of himself.
09-16-2014, 02:08 PM | #8 |
? = question mark. lol.. looks nice.
lifted, locked, rockin |
