Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 09-14-2014, 11:54 PM   #1
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Built to Order FOOSE Wheels at TNT-MotorSports
We are a Direct Dealer for Foose Wheels ...... Let us have Some Built for YOU ...... ! Here is an Example we had Built for a Pro-Touring 69 Camaro with 6-piston Wilwood Brakes and we can have them built to fit Trucks as well .... !!!!! These are FOOSE COUPE's in 18" and 20"
ksbrktracer is offline
Old 11-04-2014, 10:38 AM   #2
ksbrktracer
TNT-MOTORSPORTS
Re: Built to Order FOOSE Wheels at TNT-MotorSports
Let us have a set built for you ........ lots of designs available .......!
Old 11-11-2014, 04:13 PM   #3
ksbrktracer
TNT-MOTORSPORTS
Mounted on 315/35/20's
Old 11-11-2014, 04:15 PM   #4
ksbrktracer
TNT-MOTORSPORTS
On the car
Old 11-19-2014, 12:14 PM   #5
ksbrktracer
TNT-MOTORSPORTS
To the top for the FOOSES ...... The above wheels were built to clear 14" Wilwood Brakes front and rear.
Old 11-20-2014, 12:49 PM   #6
68shortwide
68shortwide's Avatar
How much for 20x8 and 20x10 black legends?
Jack
1968 swb on air
68shortwide is offline
Old 11-21-2014, 06:18 PM   #7
ksbrktracer
TNT-MOTORSPORTS
PM sent
Old 01-23-2015, 08:05 AM   #8
rkintn_68
rkintn_68's Avatar
can you get these in 18 x 8 & 18 x 10 5x5 , I also have the wil wood
disc on all 4 , 4/6 drop ... can see on my build thread ... thanks ...
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline
Old 01-23-2015, 09:52 AM   #9
ksbrktracer
TNT-MOTORSPORTS
I would need the part #s of your brake kits to verify they will fit.
Old 01-23-2015, 06:11 PM   #10
rkintn_68
rkintn_68's Avatar
ok I get m tomorrow ... thanks ...
Build thread :
Old 01-25-2015, 08:47 PM   #11
rkintn_68
rkintn_68's Avatar
maybe this will work ?
http://www.wilwood.com/Calipers/Cali...o=120-10939-BK
Build thread :
Old 01-27-2015, 01:37 AM   #12
ksbrktracer
TNT-MOTORSPORTS
How big are the rotors on it ? 11'' , 12'' , 13'' or 14'' ? I'm assuming if you are using D52 calipers that they are the smaller rotors.
Old 01-27-2015, 04:33 AM   #13
rkintn_68
rkintn_68's Avatar
yes ,D52 =
Rotor Dimensions
Rotor Width(In):1.04" Rotor Diameter(In): 12.19"
D52 calipers mount in the stock location over stock rotors, use the original style OE D52 brake pads and an OE 7/16-20 banjo bolt brake line. Calipers can be used with most wheels that clear the OE calipers. The front calipers with 2.00” piston provide 6.28 cubic inches of piston area per caliper, to maintain the original front to rear brake bias and use of the OE master cylinder. D52 Calipers come hardened slide pins.
Build thread :
Old 01-29-2015, 06:34 AM   #14
rkintn_68
rkintn_68's Avatar
still interested ?
Build thread :
Old 01-31-2015, 08:01 PM   #15
rkintn_68
rkintn_68's Avatar
I found some wheels , thanks ...
Build thread :
Closed Thread
