Old 09-15-2014, 07:39 PM   #1
paulbrgr9999
crossmember
Anybody know if the crossmember (the one the control arms attach to) on a 1972 c20 is identical to a 1970 c20?
paulbrgr9999 is offline   Reply With Quote
Old 09-16-2014, 07:47 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: crossmember
I don't think there are any important differences in the crossmember
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-16-2014, 08:52 AM   #3
SCOTI
SCOTI's Avatar
Re: crossmember
Might be brakeline tabs on the 72 model that aren't there on the 70 model. They're interchangeable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2014, 09:30 AM   #4
paulbrgr9999
Re: crossmember
So the control arms from a 72 c20 should bolt right on to the 70 crossmember?
No drilling, no alterations to the 70 crossmember?
Old 09-16-2014, 10:33 AM   #5
SCOTI
SCOTI's Avatar
Re: crossmember
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2014, 10:48 AM   #6
paulbrgr9999
Re: crossmember
Originally Posted by SCOTI View Post
Correct.
Thats great to hear. All my study of the issue has made me come to that conclusion also. But until we bolt the control arms on I still feel nervious about it.
thank you for the info.
paul
Old 09-16-2014, 12:10 PM   #7
SCOTI
SCOTI's Avatar
Re: crossmember
paul
No problem. Just FYI.... later arms (73-87) bolt up to the older x-members as well as older arms (63-72) bolt up later x-members.
The big changes were later x-members had disc brakes from the factory & used larger dia u-bolts for lower shafts & HD trucks have larger dia upper shaft studs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
