Old 09-15-2014, 11:28 PM   #1
Sh75
Headlight problems
So my truck has the four headlight, however the dims have the top two lights on like normal, but when you turn on the brights only the bottom right light is on. My dad seems to think it's the dimmer switch but I just replaced it a little under a year ago, does anyone else have input?
85 chevy k10 350/350/208 3.73 gears 3in lift and 33s
Sh75 is offline   Reply With Quote
Old 09-16-2014, 01:15 AM   #2
rich weyand
rich weyand's Avatar
Re: Headlight problems
It's not the dimmer switch. It's the wiring under the hood behind the headlights, plus maybe the wrong bulbs.
This is the 1986 quad headlight circuit diagram. Probably the same.
Note that the hot goes to the left (drivers) side first. If the passenger side is the only one lighting, then it sounds like a bad ground splice. Note also that the uppers (marked HIGH AND LOW BEAM) should be on as well on the other filament, so either the hot is broken to the upper high beams (LT GRN wire), or someone put the wrong bulbs in there.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
