Mounting the spare inside?
Looking to find the parts to mount a spare behind the seat. Anyone have any idea where to find the bolts? Kinda new to the 4x4 blazer stuff so any help is appreciated.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. Last edited by ArkGL01; 09-16-2014 at 09:57 AM. |
SKINNY TIRES RULE!
Re: Mounting the spare inside?
Do you have the rack that holds the spare?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Yes I do. Luckily it was with the blazer but there are no bolts to mount it.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
![]() Join Date: Jan 2014
This guy was making some, so not OEM.
http://67-72chevytrucks.com/vboard/s...d.php?t=606295 Now if I could only find a carrier myself. Keep your eyes pealed for me. |
You could just get them at the hardware store. Much cheaper than a restoration place. But if you want correct looking ones. Lmc truck or brothers trucks could get them for you I'm sure.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
They've been popping up in the parts classified board as of late too. You should place a "want to buy" ad. I doubt LMC or Brothers would have this part. I don't believe they are being reproduced.
I believe you can find similar ones on other gm vehicles...newer k5s use that hardware I think,probably others as well. Scour the junkyards and load up if you find them.They bring good money.
