09-16-2014, 11:35 AM | #1 |
1986 K30 steering part name dana 60
I need to replace the driver side tie rods. I've looked in the GM service manual(thanks hatzie) rock auto and LMC(just diagram K20). Everyone seems to call it all by different names.
What's the MOOG name for the tie rod names for pitman to steering knuckle? GM -calls them connecting rods rockauto- ? Thanks
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
09-16-2014, 02:54 PM | #2 |
Re: 1986 K30 steering part name dana 60
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
09-16-2014, 09:38 PM | #3 |
Rock auto seems to call them:
Front left inner and outer in the tie rod section Moog # ES2026R (at steering arm) #ES2027L (at pitman arm) There is also a tie rod adjusting sleeve Moog# ES362S K5 up to K30 use the same ones
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-17-2014, 06:36 AM | #4 |
Thank you gentleman!
