Junior Member
![]() Join Date: Feb 2005
Junk it or fix it? 89 c3500 rear suspension under my school bus Q's
Ok here goes: I am at my wits end with this. This project is a 1989 C3500 Chassis under my 1952 "White" School Bus. I had a shop in Portland do some work on the suspension and it just doesn't work.
I asked for the truck to be lowered about 6 inches. I asked for "helper" bags only, so that if I towed an enclosed trailer with 20 people I would be fine. I posted some pics. When I got the truck back, it was a butt clenching ride home. A couple things, the rear swaybar was left off. The bags are rated 1500 lbs, one in front of the diff, one behind it, securely mounted to the frame on the top of the bag. The bottom of the bag was mounted to a bracket that merely surrounded the helper spring. By the time I got home, the rear bags had slide backwards at the spring mount 4+ inches!! At first I connected a chain between the two lower brackets but have since made a bracket as you can see from the pic. The problem is, it drives like a 52, swinging its ass-end as I drive down the road. IT SHOULD DRIVE LIKE AN 89!! HELP! Should I junk it and buy a new Ride Tech or similar 4 link? or ??? And is the C-notch safe or too short?
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck |
Re: Junk it or fix it? 89 c3500 rear suspension under my school bus Q's
Ride Tech has a slightly better tapered sleeve bag for HD AOL use (f9100's). They are rated @ ~2000# vs the f9000's ~1500# each.
What about ditching the overload spring @ the bottom of the leaf pack? That should help take some stiffness out of it. If the 89 c3500 shock set-up is anything like my 90 c1500 after the flip kit, the shocks aren't doing anything to limit suspension oscillation during travel because they're compressed too much & @ a bad angle. I swapped to shorter shocks but the angle is still too much for them to 'work' well (& I even have Bell Techs shock extenders).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2014 at 05:52 PM. |
Agreed. How are the shock angle/ length and too many leafs in the system. Looks like the upper overload is still installed?
GOD BLESS AMERICA! |
Cluster King
![]() Join Date: Nov 2012
I am climbing on board with this one. I have had a chance to meet the owner and was curious when I heard about this rig.
You will get it straightened out. You have to consider GVRW and tongue weight for your helper bag and spring pac rates. (20) 200 lb people = 4000 lb. With the right helper, you could loose some of the spring stack and use a heavy diameter sway bar for stability in corners. That would help the ride at Your shock angle should be considered at ride height. You will have to find a happy median between empty ride quality and loaded if the bus is going to do double duty. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Jan 2011
One thing I see that may be an issue is the C-notch. All yo have for frame now for 6 or 8 inches is a piece of 2" box tube. It is going to flex under load and will not carry the weight of a trailer. It may be flexing under the load of the springs. The helper bags need to go in the way they are done. The structure around them will not carry the load they are to help with. Can you get better pics of the shocks and the way the frame is done?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
