09-16-2014, 06:03 PM | #1 |
Why did 4x4s never get big blocks?
In our 67-72 series what kept GM from putting the 402 in it? Was it a fitment issue or a marketing decision (it's always the latter, but was it forced by the former?).
For that matter why was the 427 or 454 never offered, even in the big 30s?
09-16-2014, 06:39 PM | #2 |
Re: Why did 4x4s never get big blocks?
They moved the engine rearward in the 4x4, for oil pan to axle clearance. Without making a 2nd firewall stamping, and possibly creating more necessary changes, I'm guessing they just took the easy way out, by not offering a big block in a 4x4.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
09-16-2014, 06:45 PM | #3 |
Another theory might be that they didn't want to warranty the drive train, with the massive torque of the BBC on 4x4 equipment.
They also didn't offer the 292 L6 [another torque monster] in the K/5.
09-16-2014, 06:55 PM | #4 |
Neighbor put a 396 in a 72 4X4 with no firewall clearance issues at all. Not sure what he had to do the pan though, if anything.
Terry Soon to be retired and moving to Bristol, TN. |
09-17-2014, 12:35 AM | #5 |
Yeah, and I used to run a '67 K/10 Suburban with a 454. PO told me he got frustrated with trying to pull his boat up to the [AZ] White Mountains. When the original 283 couldn't cut it he put in a 350. When he thought the 350 was too slow he dropped in a 454.
I'd like to ressurect that truck, there were only like around 1600 1/2 ton 4x4 [K/10] Suburbans in 1967, kinda rare. But I can't afford to rebuild that BBC, when it only got 8 highway and 6 city miles. It would pass anything on the road but a gas station. And it only liked Premium. The points distributor fit OK. When I swapped in an HEI, it got tight. Don't remember any oil pan issue. The BBC would also beat the driveline into submission. I was replacing uni- joints every 6 months.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-17-2014 at 12:42 AM. |
09-17-2014, 04:08 AM | #6 |
The story I was told is that it had to do with torque, the 396's would put too much stress on the transfer case and Dana 44 front axle. The 351 V-6 was not available in 4X4's either. The first year for the big block in a 4X4 was 1982, and then it was only available in the K-30 with the Dana 60 front axle. Ford was basically the same way, no 390's in 4X4's.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-17-2014, 07:11 AM | #7 |
Torque multiplication through the transfer case in low range.
It doubles the torque and the axles are not up to the task. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
