Old 09-16-2014, 06:45 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Power Steering issues
Ok guys, I have absolutely NO power steering at all. The pump isn't whining or making any noise at all. Also the fluid doesn't appear to be churning or moving inside at all. I've taken both hoses off at the gear box and fluid is coming out.
I decided to yank the pump off and look at the backside of the pump where the pressure hose goes in. I bought the fitting that allows you to still use my original 71 pressure hose.
My question, is there any sort of check valve that should be in there that might be missing? I don't want to change the pump if there isn't anything wrong with it.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-16-2014, 08:48 PM   #2
uxdesigner
Re: Power Steering issues
I have the same adapter with no problems. You may want to check that return line, it looks crimped at the bend in the picture...
uxdesigner is offline   Reply With Quote
Old 09-16-2014, 09:24 PM   #3
5150
C10 Club Tennessee
5150's Avatar
I actually bent it when I was taking it out.
Bryan
www.gmtruckshow.com
Old 09-16-2014, 11:13 PM   #4
ls1nova71
ls1nova71's Avatar
Well, now you're probably going to have to change the pump anyway. I would just put another one on it, that's going to be the easiest fix.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
