misc. accessory harness options....
As some of you know, I've been building replacement power window and door lock harnesses which is a common issue with these trucks and I've started building driver or passenger specific OEM style replacement harnesses. This way, if you only need one side or the other you can get them individually now.
So, I am happy to announce I have the LH, RH and CENTER harness sections available. If you opt for a full replacement harness, I can now offer them with OEM connectors, my update full harness now incorporates weather pack connectors for improved resistance to the elements and then individual harness sections are available with OEM connectors for a plug n play to your existing GM stock harness.
So replace in full or replace only what you need. PM me with any questions you may have! Thanks to all for your support so far and yes, I am busy building harnesses still for a variety of stock and not so stock applications-I'm happy to offer my services for everyone-I truly enjoy helping out with your projects on the electrical side! More NEW projects coming down the pipe soon for our squares as well-I'll post up in the electrical section when I have new harness integrations ready to order!!
