09-16-2014, 09:26 PM | #1 |
Th350 Kickdown Cable Help
I could use a little help hooking up my kickdown cable. The cable that came with my TH350 was way too long so I bought the B&M universal cable. It turns out that the ends that hook up in the transmission are completely different. The other cable end was more like a wire that was fed through a hole on the transmission.
Unfortunately, I broke the little tab that the little wire went through on the transmission side, the one that bolts to the valve with the spring inside it so I can't reuse it. I didn't see a way to hook up this new cable to it anyway. This is the end on my new cable. Anyway, does anyone know what I need to be able to hook up this new cable to the transmission? Thanks. |
09-16-2014, 09:51 PM | #2 |
Re: Th350 Kickdown Cable Help
Bump
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-17-2014, 12:35 PM | #3 |
Still looking for help.
09-17-2014, 12:52 PM | #4 | |
You can get the correct kickdown cable at just about any auto parts store for about $20 bucks. I've never had much luck with generic, universal, one size fits all parts. Not sure what you broke... May need to take a trip to a trans shop to find a replacement part.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
