Old 09-17-2014, 12:25 AM   #1
zipper
1968 Disc Brake Conversion
I own a 1968 Short Bed Stepside C10 and looking to upgrade the front brakes from drum to disc. I was looking for kits and stumbled upon this one http://www.ebay.com/itm/330946117099?redirect=mobile
Is this all I need to upgrade? I'm looking for a kit that won't require any customization or anything, just bolt on. Sorry if this has been covered before. Thanks!
zipper is offline   Reply With Quote
Old 09-17-2014, 07:00 AM   #2
PGSigns
PGSigns's Avatar
Re: 1968 Disc Brake Conversion
Look just above this post in the FAQ section and the last one is the one on brakes. Everything you need to know before making a choice on what way to go is in there. Good reading.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-17-2014, 07:33 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Those spindles look used.
I would buy from a board vendor first,... or call www.earlyclassic.com.
You will also need a disc brake M/C and prop valve.
You will have to fabricate a few new brake lines.
The rotors in the ebay add are 6-lug and will only work with 1971 and later 6-lug "disc brake" wheels. (to clear the calipers)
Keith
Convert to disc brakes.
Old 09-17-2014, 11:35 PM   #4
zipper
Which board vendors would you recommend ordering through?
Old 09-18-2014, 06:40 AM   #5
lolife99
lolife99's Avatar
Look here:
http://67-72chevytrucks.com/vboard/showgroups.php
All the Vendors on the board are listed in GOLD color.
Try Pro Performance at http://www.azproperformance.com/home.php
Keith
