Old 09-17-2014, 03:12 PM   #1
61K10
61K10's Avatar
door outer window felts
on the window outer felt that runs across the top and down the rear of the door.do you glue in the channel? seems it has to to stay in place. what did you use for glue? w/strip? other?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-17-2014, 03:17 PM   #2
sixysixss
Re: door outer window felts
I did not use any glue. They press into place and you can almost feel a slight snap when it is properly seated.
Rob
sixysixss is offline   Reply With Quote
Old 09-17-2014, 03:45 PM   #3
61K10
61K10's Avatar
there is nothing on the lower channel to help hold it in. maybe a 61 is different.
1961 chevy K10
Old 09-17-2014, 03:53 PM   #4
sixysixss
You are probably right, 61 must be different. Sorry I couldn't help.
Rob
1966 GMC 1500
Old 09-17-2014, 03:55 PM   #5
61K10
61K10's Avatar
thanks for the reply
1961 chevy K10
Old 09-21-2014, 09:10 PM   #6
enamelplanet
enamelplanet's Avatar
I'm also wondering what would be the best glue to use.
64 Fleetside, Shortbox, BBW
66 Fleetside, Longbox, 4x4 SOLD
70 5.3, Fleetside, Shortbox
enamelplanet is offline   Reply With Quote
Old 09-21-2014, 10:20 PM   #7
62 Barnfind
62 Barnfind's Avatar
I used weather striping adhesive on my 62 down the lower inside channel. Mine also had a tab that the channel slides into. You have to cut to the felt channel to fit so it will slide in. But on the outer part it snapped in place. Do you have original or replacements?
Your truck is really coming out nice!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 09-22-2014, 12:53 PM   #8
61K10
61K10's Avatar
I installed the d/s without glue haven't done the p/s yet. will use some adhesive and compare.
1961 chevy K10
