09-17-2014, 03:46 PM | #1 |
6l80e drive shaft ?
I have a 6l80e from 09 G8 I wont to run a one piece driveshaft I have heard I could use a 400 bolt on yoke and have it machined to replace the 3 bolt flange looking for some input or a better idea thanks doug
09-22-2014, 05:16 PM | #2 |
Re: 6l80e drive shaft ?
09-22-2014, 07:51 PM | #3 |
meowMEOWmeowMEOW
Yea, but we've steered away from it (and probably done the same for others). Yes it can be done, and has been done, but I think the general cost and time involved makes most folks look for another source vehicle that came with the "normal" connector.
You may have better luck finding a more in-depth explanation over on LS1tech. I have seen this however: http://www.shop.gforce1320.com/product.sc?productId=354 Its designed to bolt a regular driveshaft into a GTO with a tranny swap.
09-23-2014, 12:44 AM | #4 |
You can check out this guys build, not the cheapest route but it did bolt right up that 3 bolt flange. http://67-72chevytrucks.com/vboard/s...358692&page=46
09-23-2014, 09:40 AM | #5 | |
09-23-2014, 11:08 AM | #6 |
Just another link, these are the guys that built the one for Hart_Rod in his build http://www.driveshaftshop.com/
09-23-2014, 12:47 PM | #7 | |
09-25-2014, 10:23 PM | #8 | |
Yolk, http://www.ebay.com/itm/Transmission...-/130322434555, This is Cheap! Is has a Spicer part# but not sure if it is Spicer or not. DriveShaft, http://www.dennysdriveshaft.com/p136...lip.html#photo. I also recommend a 1350 Yolk for the rearend as well to make the U-joints the same. |
09-26-2014, 08:49 AM | #9 | |
09-26-2014, 01:06 PM | #10 |
You could always use that driveshaft with slip yoke clinebarger posted and this flange http://www.driveshaftshop.com/drives...nger-05-06-gto.
This would be easier than converting your transmission from your 3 bolt flange to a slip yoke style to use a TH400 yoke or the 6l90e 1410 yoke. |
09-26-2014, 08:00 PM | #11 | ||
I'm an amateur with a Bridgeport Lathe, But even I know how to do this. Quote:
The next conversion I do with a car 6L80E, I will try this adaptor....Thanks DLW. |
09-26-2014, 09:55 PM | #12 |
grate info I like the idea of turning down the 400 yoke because its less parts, but the adapter looks easy
09-26-2014, 11:11 PM | #13 |
My driveshaft uses an adapter on the tranny that connects to the driveshaft via a Porsche CV joint.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-27-2014, 06:04 PM | #14 |
09-27-2014, 07:56 PM | #15 |
Thanks. The driveshaft is supposed to be rated for 1000+ HP.
http://www.driveshaftshop.com/domest...ece-driveshaft
09-28-2014, 01:41 AM | #16 | |
09-28-2014, 01:56 AM | #17 | |
Now if they made more than one stand alone 6L80E TCM controller ..I was bummed when I called Mast Motorsports that had this working with their PCM to find out they quit on it and don't offer it. |
09-28-2014, 05:55 AM | #18 |
That's correct.
09-28-2014, 06:33 AM | #19 |
Wholly smokes you fellas have some nice rides! Excuse me - I have to go fertilize my money tree! LOL
That billet unit looks awesome. I am inspired. The search for a doner is on.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-28-2014, 08:55 AM | #20 |
10-4 on the money tree $$$$$ this motor only makes 360 hp but it will be a daily driver and long trips with the airstream it has to be dependable
10-03-2014, 05:49 PM | #21 |
thanks every one for all the input doug
10-16-2014, 09:15 AM | #22 |
I got my 400 yoke back from the machine shop yesterday her are some pictures I found out you cant go to your normal machine shop you have to go to your local jesse james al the big shops wont to hit a home run on every job I hope this helps someone it cost me 45.00 for the yoke 60.00 for the machine work im not cheap I just didn't like using the extra part when using the adapter doug
10-16-2014, 11:29 PM | #23 |
I'm glad you found a competent machinist.
Reinstall the 3-bolt yolk with the Center Nut. Cut off the Output Shaft flush with the Nut. A portable Band Saw does the Cleanest/Coolest Cut. Install TH400 yolk & Nut. Test a U-Joint for a range of motion. |
10-17-2014, 09:17 AM | #24 |
ive been tinkering with old cars and motorcycles since I was 9 that's almost 58 years of experience I shouldve known better than to go to a production shop but at the same time I knew I did not wont the adapter although im sure it works just fine a DA works grate but but perfect paint takes a stick the is in the details
10-29-2014, 08:25 PM | #25 |
I just had a yoke from a 6l80e truck machined for my ls swap out of a 2011 camaro
