Location of Vin number
I am starting the process of applying for a lost title. Is the Vin location for my 62 on the right side door frame? That is the only one I see. Is there another place?
Thanks!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Re: Location of Vin number
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
Top of driver side frame rail around upper a-arms will give a 2nd partial vin if the frames original.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks! I just wanted to make sure.
there are three locations for the vin on each truck the first one is in the door pillar either on the window pillar of a 60 thru 63 or on the top drip rail at the interior of the door for the 64 thru 66 the 2nd location is at the driver side top front rail the 3rd location is under the cab on the drivers side on top of the rail.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#6 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'm pretty sure it's also linked in the FAQ's.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Thanks to everybody for the help. I just wanted to double check before I fill out the paperwork.
