Upper chrome clips
Hi all,
I am just in the middle of my final assembly. When I drilled the holes for the upper chrome I drilled them for the old style chrome clips that used a much smaller hole than the clips on the market today. The intent was to use the actual clips because I didn't want to use the plastic ones with the adhesive on them. I just ordered a bag full of clips and the ones available now use a larger hole. Can anyone suggest a vendor who can possibly supply the metal clips that use a arrow type pin verses the two post style that is available on the market now? Any help or advice would be greatly appreciated. I would not want to have to drill the holes out at this stage as the truck has been re painted. Thanks.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
Moderator
![]() Join Date: May 2007
Re: Upper chrome clips
I just drilled the holes bigger. Truck had fresh paint too. If you go this route use a step bit as they do not walk/twist and your paint won't get damaged.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
