Pics of bagged W/O Z,ed or PB fronts
I was wondering if there is a thread of bagged trucks or Blazers that don,t have any extra work done to the the front like pancakeing the crossmember or portbuilt or Z,ed frames,just simple bag jobs.I looked in the lowered section but not many people tell you if it is alterted.
Re: Pics of bagged W/O Z,ed or PB fronts
This has our Stage 1 Front kit. Airbag replaces the coil spring with an upper plate that bolts to the crossmember and a lower cup that rests in the spring pocket on the lower arm, and a shock relocation kit.
Rear is a Stage 2 Basic that has our two-piece bolt-in c-notch, an airbag that replaces the coil spring, a fully adjustable trac bar, and a shock relocation system.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#3 | |
Just imagine that it's a square body! LOL
I will have to see if I can dig up some pics of a 73-87. Nate
While you looking for pictures of 73-87, if you have pictures of 64-66 with this setup please post some. Thanks
#6 | |
Stage 1 front and Stage 2 rear basic:
Thank you for the picture.
Is this a Forum member, I would like to ask the rocker to floor measurement when aired out. Im low now and I think if I have read right if I do this I could be higher than my height now when aired out. Or if you know the answers, again thanks. |
![]() ![]() This is mine bagged currently, but I just got the front porterbuilt extreme dropmember in so it will be installed soon as I get it back from powdercoat! The rear I'm unsure what I'm gonna do yet, PB dropmember or custom cause it will have 24x15's out back.
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
#11 | |
![]() '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
Mild porterbuilt on bags with 22" & 24" wheels
1967 C10 SWB 6.8L/4L80 |
#13 |
thats as low as you're gonna get without cutting things up.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#14 |
#15 |
Oh let me get in. PB with that 67-72 style truck how low is the cross member to the ground? Also with a bigger notch and the bags still in the stock spring location in the back how much lower will it go?
#16 |
I'm not sure but if it's close to or the equivalent of a Z then I'd assume its around 5 or 6". Based off people saying their bagged lca are 3" off and z'ing i believe is usually 1.5-3" raise?
#17 |
Bagged or cupped? kinda lost me there?
#18 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Love those wheels!
#19 |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
