Really dumb ls question??
So I just read a article on fb about ls motors, it showed lq9, lq4, ls6 and so on, these where mostly the car engines it didn't say anything about the 5.3's, I have a 2004 5.3 in my truck...what acronym does it have?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Re: Really dumb ls question??
There is several codes for the Vortec engines, LM7/L59/LM4/L33. Your 2004 should be an LM7.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
lm7, l33 and ly5. might be more.
BTW, LQ4 and LQ9 are truck engines.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Yup DLW is right, your motor is an LM7 unless it is flex fuel, then it would be a L59. The LM4 and L33 were the aluminum block 5.3L. The L33 is the HO version.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
LY5 and LMG are the Gen IV iron blocks, the LH6/8/9 are the aluminum Gen IV variants. I may have forgot one or 2 but that about covers the Gen III and Gen IV 5.3L
Sidebar:
When we introduced these GenIII engines for the GMT800 program strategy was to have three small block variants to choose from: 4.8L 5.3L 6.0L There was also the 4.3L V6 as the most basic entry, and the L18 big block up top. The thought was to try to drive buyers down into the 4.8L engine for better fuel economy and better vehicle base price. It didn't work for two reasons: a) Truck buyers want "the biggest engine available" regardless of fuel economy and price ![]() b) The 5.3L outperformed the 4.8L in almost every area, including fuel economy Bottom line: that 5.3L is a pretty sharp little small block. ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#7 | |
I agree, and I was mostly asking for badges, can't really put the 80's era badges on there since most of it is modern now lol
Would a lsx badge be legit?
Sure why not I mean it is an LS motor, however I think the X designation was reserved for their 376 and 454 models but who cares, plus the LSX badges look cool, I think most of them use double sided tape so don't stick it on there unless you plan to leave it on forever.
There are several different materials available, aluminum, plastic and Polished Stainless Steel. You can also buy letters and numbers separately and spell out anything you like. Ebay is a good resource, here is a search for the 5.3L emblem. http://www.ebay.com/sch/Car-Truck-Pa...p2050890.m1602 Last edited by Xeen; 09-18-2014 at 03:20 PM. |
meowMEOWmeowMEOW
If you wanna REALLY pick at hairs;
LSx refers to the LS(family) of engines....lower case x denoting a variable to be replaced with whatever specific suffix is appropriate. LSX refers to the LSX GM performance engines specifically. There is a tendency to interchange them. All lower case lsx can end up meaning either.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Check out this link:
http://en.wikipedia.org/wiki/GM_small-block_engine If you scroll down to 3rd/4th gen it has every engine code they made, and an explanation of what each one is.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
#12 | |
Of course, this is coming from someone who has a 4.8. I got a good deal as they go for super cheap, and I figure I can always put a turbo on it if I want more power.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
#13 | |
#14 | |
