Old 09-18-2014, 05:47 PM   #1
Brave71
Fuel line, brake line routing on 72
Does anyone have pictures of fuel and brake lines inside the frame rail below the fuel tank... Or know of a thread..I have new pre bent fuel and brake lines and want to make it look good...thanks
Brave71 is offline   Reply With Quote
Old 10-05-2014, 08:10 PM   #2
zamboni2354
Re: Fuel line, brake line routing on 72
I'd be interested in seeing this as well.
jeff
zamboni2354 is offline   Reply With Quote
Old 10-05-2014, 09:11 PM   #3
In The Ten Ring
I have pics. I'll try to get those up tonight.
If I forget, drop me an email or keep "ttt" this thread.
In The Ten Ring is offline   Reply With Quote
Old 10-05-2014, 09:16 PM   #4
litew8
litew8's Avatar
Below the fuel tank? Doesn't the tank connect to the line via gas hose?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-05-2014, 09:44 PM   #5
In The Ten Ring
Who are you---a clone of Wrecked Chevy?
Here are my pics of my fuel and vent lines (second upload attempt).
1). Left to right: fuel line, rear part of vent line, front of vent line.
2). Under cab: top is rear of fuel line, middle is brake line, bottom is rear of vent line (notice is passes through the frame member).
3). Under passenger side door: the connection of the 2-piece vent line.
4). Vent line front: here the vent line passes through a spring and attaches to the frame via a clip. The black hose connects it to the charcoal canister.
These are all the pics I have on file. I hope they help.
Old 10-05-2014, 09:48 PM   #6
FirstOwner69
FirstOwner69's Avatar
I'm not sure if this is what you are asking for, but here are 5 pictures tracing the lines from front to the tank connection on my 69 3/4 ton. I know the front lines are different for your disc brake 72, but these are likely the same. Perhaps someone can confirm.
Edit: Oops... forgot about your vent line...
FirstOwner69 is online now   Reply With Quote
Old 10-05-2014, 11:25 PM   #7
litew8
litew8's Avatar
Never heard of Wrecked Chevy - though I'm sure you have good intentions He asked for 'below the fuel tank' not the entire line. And look, you've got the the gas hose.
Old 10-06-2014, 12:20 PM   #8
zamboni2354
On a 72 shouldn't there be 3 lines that run in the frame?
1. a line that runs to the charcoal canister
2. a fuel line that runs to the fuel pump
3. a return line that runs to the fuel pump.
so with those three plus the brake line there would be 4 hard lines running in the frame?
In the ten ring - so from top down you have the fuel line, brake line, then vent line. does yours have the return line? my fuel pump has two connections on it.
thanks
jeff
Old 10-06-2014, 10:30 PM   #9
BIG ORANGE
BIG ORANGE's Avatar
I got a question, 350 sbc w 4barrel, fuel line from tank to fuel pump size 3/8
307 sbc w 2barrel the same line would be 5/16
Is this correct?
Just removed the tank from the cab and installed a new fuel tank under the bed so I'm running new fuel line from the new tank to the fuel pump so wanna get this correct on the fuel line size.
I have a 350 sbc w a 4 barrel carb..
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 10-08-2014, 10:27 AM   #10
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Run 3/8.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 10-08-2014, 04:13 PM   #11
72bowtiestepper
X2 3/8" line is what you want.
72bowtiestepper is offline   Reply With Quote
