Old 09-18-2014, 09:35 PM   #1
Big Blue
Big Blue's Avatar
ac brackets and compressor
Question??? Will the brackets and compressor from a 88 fit on a 350.
The engine that it is going on is a carb set up. not tbi. The valve covers on the 88 have the bolts in the middle. I have the older set up with 4 bolts to fasten valve covers down. Is their a difference in the engine block that the AC brackets Bolt in to?
Thanks for looking, John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
