08-11-2003, 07:38 PM | #1 |
cab 3/4 to 1/2
will a 68 3/4 cab fit on 67 1/2 frame i already have it on the frame wholes match but when it come to lining up the 67 feners and hood it all dont fit thought maybe it was cause the cab came of 3/4 ton
08-11-2003, 07:44 PM | #2 |
Robert Olson Transport
i know of no reason why it wont line up unelss the core support is diffrent???
08-11-2003, 08:02 PM | #3 |
Where's my beer?
TTT
I would think that everything would fit without any major problems, you better figure out how to get everything lined up and let me know because that's exactly what I'm doing in the next couple of months with my '67 lol J/K
Paul How do you make the invisible, visible?.........You take it away. |
08-11-2003, 08:28 PM | #4 |
PROJECT 7DEUCE
I put my 72 1/2 on a 69 3/4 ton and had no problem's with part's lining up even when I swapped over my 1/2 to running gear.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-11-2003, 08:32 PM | #5 |
Fabricate till you "puke"
The cabs are the same, but the 3/4 ton frame had different rear brackets & cab cushions......use the cab mounts for the 1/2 ton truck & you should be ok. I beleive the rad support cushions are also different on the 67(thinner?) Maybe one of the vendors can shed a little more light on the subject. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-13-2003, 05:10 PM | #6 |
well thanx for all the info im just gonna tinker with it and post on how it went
08-13-2003, 05:40 PM | #7 |
its all about the +6 inches
Crazy is right.
The 2 wheel drive 1/2 ton had cab mounts that differ from all the other trucks. If you swap C/10 2 wheel drive mounts onto it, it should all line up. |
