Porterbuilt notch cover cant access airbag fitting
Hey Guys
I was looking for any pics , good ideas for accessing airbag fittings As i have noticed that once the fitting are in the airbags they are too close to the notch cover and wont be able to access them from underneath I was thinking of making a cut out so there is a view of chassis but it has to look good and neat ( as its going to go in a big show) and also be able to drive like that. Any body done this Here is a pic http://i1201.photobucket.com/albums/...871302_n-1.jpg ![]() |
Re: Porterbuilt notch cover cant access airbag fitting
Here is my bag with cup.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
![]() Join Date: Jan 2011
Where is you bag at? Got a picture?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Here is a pic not a great one but you can see the 2 airbag fittings above the Portbuilt notch i noticed after my notch cover got built the fittings are just under the cover and u wont be able to unscrew them
So now i need to cut holes to access them so i have to try and make it look like it supossed to be there. a cover with i view plate is what im thinking but im not sure how to make it look nice so looking for some pics ![]() here is a pic of what im looking at doing but try to make it look like one piece somehow ![]() |
Make a nice cover plate in your sub floor and put it in with Dzus fasteners. The it will be out of sit when you put in the flooring.
Jimmy
http://d136nqpz68vrmx.cloudfront.net...captop2011.jpg
How about some small motorcycle gas caps. Seen some flush mount ones.
