Old 08-11-2003, 07:48 PM   #1
81lwb350
big block lover
454 swap..
hey i found a rebuilt 454 here in town for a great price..ready to swap...
what all could i expect to have to change to get this in my 81...there is currently a 327 with a th350..2.73 rear gears...
im gonna look at the engine this week, hopefully tomm....
are there things i should look for concerning the 454 specifically
never really messed with one.
i would think that the th350 would get crushed with the 454 torque and power.....so i am thinking that i could get a th400 to go with it..."since i found one of those also"...
how would i know if i needed a short or long shaft?
what else should i expect to have to change...
looking forward to your tips...
thanks,
anthony
81lwb350 is offline   Reply With Quote
Old 08-11-2003, 09:39 PM   #2
AirMale
AirMale's Avatar
You can start your grocery list with
Brackets and pulleys (PS pump)
Headers
Waterpump
Fuel system
Radiator (4 row)
Turbo 400 and new converter
Motor mounts
After you finish with all that you probably will need regular rear tire replacements
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 08-12-2003, 01:40 AM   #3
81lwb350
big block lover
well the engine im looking at is supposed to be complete...
so maybe i wont have to get all the pulleys and stuff...
i hope this works out...
Old 08-12-2003, 06:53 AM   #4
bigblock73
yeller
bigblock73's Avatar
Engine mouns are the same or a 350 and 454.
Otherwise Airmale listed pretty much everything. Good luck and keep us posted.
...Jeff
bigblock73 is offline   Reply With Quote
Old 08-13-2003, 03:21 PM   #5
81lwb350
big block lover
can i use my existing ps pump, alt, and A/C compressor...
do i need to change pulleys on those..
i have been told that a th350 will holp up the the 454 as long as i dont do any towing or heavy hauling...
i plan on having the th350 rebuilt shortly after installing the 454.
i guess i can just beef it up...or would it be cheaper to get a th400 and rebuild it?
so many questions, so little time!
81 custom deluxe lwb
454 bored .030 over w/ small RV cam.
2.5 exaust- thrush turbo muffs.
th350 getting beefed up soon!
Old 08-13-2003, 03:34 PM   #6
Jonboy
Slots go on anything!
you can use all of those accessories, but you will need to use 454 brackets for them. I would use the 400, as if you are making any power, it will kill the TH350 in a hurry.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-13-2003, 04:49 PM   #7
gldevall
gldevall's Avatar
Hey Anthony, not to hi-jack this thread, but are you going to the Street Legal drags this Sunday at No Problem? I may go, it depends on the shape my truck is in. I got a tach and gears coming this week.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 08-13-2003, 05:04 PM   #8
81lwb350
big block lover
gary... i might be able to go...i didnt know that was goin on though....pm me if you go..i dont think i have anything to do on sunday...and i have a buddy coming in so that might be a kick ass day...how much is the entry there?
Old 08-13-2003, 05:54 PM   #9
gldevall
gldevall's Avatar
Here check this out, http://www.noproblemraceway.com/npr/...al%20Drags.pdf
I probably will not know if I'm going until Saturday, but I will pm you either way.
Old 08-13-2003, 06:36 PM   #10
81lwb350
big block lover
awesome.....gotta see the truck and suv eliminator!
dont forget to sand bag..
Old 08-13-2003, 06:38 PM   #11
Desert Rat
Desert Rat's Avatar
I put a big block in my 79.Only thing you need is the motor the motor towers are the same,the water pump pulley i found was the same.you can use the small block PS pump,youll just need the big block AC brackets,crank pulley,ps brackets,alt brackets.your T350 will be fine,as long as you arent doing weekely drag racing,or heavy towing.If you have any questions email me
Desert Rat is offline   Reply With Quote
Old 08-14-2003, 09:43 AM   #12
81lwb350
big block lover
if the water pump pulleys are the same, then could i still use my small block fan?
Old 08-14-2003, 09:23 PM   #13
81lwb350
big block lover
i got it....
i went and picked up the 454 today after work...
man, i am so exited...cant wait to get it in....just a couple of weeks to gets the rest of the parts that i need and it peelin tires....
wish me luck...
i'll take pics and take some notes along the way for everyone else....
thanks for everyones help!
Old 08-14-2003, 10:35 PM   #14
Russell
Professional Grade
Russell's Avatar
Byebye gas milage, hello burnout!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
