Old 09-19-2014, 01:35 PM   #1
no1udknow
no1udknow's Avatar
need help decoding this engine...
So I was looking to see the engine configuration on my truck and I cant seem to find out what it is. The casting on the drivers rear is 3970010 which means it is a 68-72 motor but the engine code info on the front dosent match anything. The number stamped on the water pump boss is V111CTYY and there is a partial vin code (which dosent match the truck... not surprised) but the only thing I found that said CTY says its a 400?
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-19-2014, 01:44 PM   #2
no1udknow
no1udknow's Avatar
Re: need help decoding this engine...
Looks like I fou d it actually, 1976, 350, 165 hp....found a decoder on superchevy.com
Built not bought!
Old 09-19-2014, 03:23 PM   #3
sKnNyPpY
sKnNyPpY's Avatar
Have a web link to that decoder? I'm looking for it now.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 09-19-2014, 03:30 PM   #4
geezer#99
geezer#99's Avatar
A couple more.
http://www.nastyz28.com/decode.php
http://www.mortec.com/
geezer#99 is online now   Reply With Quote
Old 09-19-2014, 04:07 PM   #5
no1udknow
no1udknow's Avatar
i was going to list the nastyz28.com one, but it was incomplete as far as suffix codes go, this one was awesome
http://www.chevymania.com/partsid/su...fm?block=Small
Built not bought!
Old 09-19-2014, 04:09 PM   #6
sKnNyPpY
sKnNyPpY's Avatar
Good one! Just found it.
Old 09-19-2014, 04:53 PM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have the same motor with a different suffix code...Can you run it? V02O5TDJ...Dont mean to hijack the thread, just cant make heads or tails out of that last link. Thanks
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-19-2014, 05:02 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
TDJ = 1972 175 hp 350 with a 4bbl. Or 1980 155hp 350 with a 4bbl... Lots and lots of those made... I have the same code on my '72 GMC's 350
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-19-2014, 05:02 PM   #9
no1udknow
no1udknow's Avatar
So, you need to use the chevymania link in conjunction with the nastyz28.
You need to get the casting numbers from the right rear just in front of where the bell housing mates up. Should be a leter, 2 numbersm a space, and then another number, that will tell you the year, the single digit at the end will be either a 2 or a 0. Then you take the last 3 letters of the v0205tdj, "tdj" and plug it in to the chevy mania decoder. It says it is either a 1972 350 or a 1980 350. V=Flint, MI factory, 0205 is the month and day it was produced, and tdj means a 350
Built not bought!
Old 09-19-2014, 05:19 PM   #10
sKnNyPpY
sKnNyPpY's Avatar
I've got a 26-3970010 which comes to 350 1969-79 but
either V0614TR which is a 78 LeMans 305
or V0614TRJ 72 C30 Truck 350 with a TH400.
or V0614TRC 73 4x4 350
I can't find the date code and don't necessarily want to remove my valve covers. I also have a long water pump with the alternator on the passenger side and compressor on the drivers side with a vintage air replacement of the factory AC.
I know I have a TH350 from replacing seals and a long water pump I can fit my fingers in between. Hope this is a TRJ or TRC replacement. There may be a worn off last digit after the TR...
Attachment 1303460
Attachment 1303461
Attachment 1303462
Old 09-19-2014, 05:37 PM   #11
Ironangel
Ironangel's Avatar
Cool, no wonder I wasnt getting anywhere! I was entering VO2 instead of TDJ...Gary, is your 350 a four bolt? PS. Thanks you guys!
"Two Seventy Two's"
02 3/4 ton Express
Old 09-19-2014, 06:06 PM   #12
no1udknow
no1udknow's Avatar
Attachment 1303460
Attachment 1303461
Attachment 1303462
date code is on the right rear of the engine where the bell hoising bolts up basically oposite the 3970010
Built not bought!
Old 09-19-2014, 06:20 PM   #13
sKnNyPpY
sKnNyPpY's Avatar
I think it might be in this junk..the 6 looks visible in the first shot. I will get out the cleaner and the camera tomorrow morning. Thanks!
Old 09-19-2014, 06:32 PM   #14
sKnNyPpY
sKnNyPpY's Avatar
Sorry...indicated better where I think it is in these pics, Thanks for helping and letting me hijack....
Old 09-19-2014, 07:52 PM   #15
kwmech
other side, behind the drivers cyl head
Old 09-19-2014, 08:05 PM   #16
no1udknow
no1udknow's Avatar
Built not bought!
Old 09-19-2014, 08:12 PM   #17
sKnNyPpY
sKnNyPpY's Avatar
Got that one, looking for the date code, pretty sure it is behind the tranny dip stick under that junk
Got this one from the front, too ther may be a worn off last letter C or J
Old 09-19-2014, 08:28 PM   #18
sKnNyPpY
sKnNyPpY's Avatar
Really trying to find the year. Getting confused
From Z28
"Casting Date
Small block casting date is located on driver side (???) rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails.
Casting Date Example: E038 - (E = Month, 03 = Day, 8 = Last digit of model year (1978)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec"
or from Mortec:
http://www.mortec.com/images/diagram1.gif
"Casting number and casting date locations
The diagram above shows where each of the casting identifiers is located on the engine. (1) shows the location of the HEAD CASTING NUMBERS and the HEAD CASTING DATE located under the valve covers, in the rocker arm valley. (2) shows the position of the BLOCK CASTING DATE on the rear ledge of the block near the bell housing mounting surface. If you have an early big block or a late model smallblock, the BLOCK CASTING DATE may be on the passenger side of the engine block, (see 2A), instead of the rear ledge of the block. Some smallblock blocks may also have the BLOCK CASTING DATE on the driver's side of the block. "
Old 09-19-2014, 08:43 PM   #19
no1udknow
no1udknow's Avatar
From Z28
"Casting Date
or from Mortec:
i think "drivers side" was a typo, I found mine it was on the passenger side just forward of the tranny dip stick mount. mine was like *j02 6 *
Built not bought!
Old 09-19-2014, 08:46 PM   #20
sKnNyPpY
sKnNyPpY's Avatar
I WILL FIND IT...Brake cleaner and perseverance....or opening the valve covers, but they aren't leaking SOOO...(it runs pretty great shut up and drive ur dang truck idjit...)
Old 09-19-2014, 08:48 PM   #21
no1udknow
no1udknow's Avatar
Attachment 1303536
i used a razor blade and scraped the paint off mine by holding the razor blade perfectly perpendicular to the surface, made it very easy to read
Built not bought!
Old 09-23-2014, 01:47 PM   #22
sKnNyPpY
sKnNyPpY's Avatar
I've got it!
26-3970010 which comes to 350 1969-80
Flint MI June 14 assembled
F122 cast June 12 1972
Not original but a good engine
Old 09-23-2014, 07:49 PM   #23
GASoline71
GASoline71's Avatar
It sure is.
Gary
